Which Tuner
Old Nov 28, 2020 | 12:27 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Default Which Tuner
Ok, So I bought my first Twin Cam. 2013 Street Bob with a 103. I found a set of Hillside stage II heads ( Recently machine with no miles on them) and a set of Woods TW 5-6 cams that I will be installing. The heads and a .030" HG will put me at 10.1:1... I have never tuned a fuel injected bike but have a lot experience with a Wego III and carburated bikes (Evo's)... So Getting the AFR's and timing right won't be an issue but I do need to hear from you all on what tuner I should go with... I've done a little research and so far I'm leaning toward the Dynojet TTS master tune... I am familiar with setting up timing curves on the Wego III and downloading them. But have never gone totally digital (computer) so a little insight would be very helpful... I have talked to an engine builder that I have dealt with in the past and he really likes Direct Link but I don't think that that system will allow me to make changes... Or will it? Thanks... Bob...
Old Nov 28, 2020 | 12:56 PM
rigidthumper's Avatar
rigidthumper
The tuning device?
TTS mastertune.
Are you in Poolville, TX? I'd call Steve at GMR. ( He's in Keller) He can sell you a tuner, and tune your build.
Old Nov 28, 2020 | 01:02 PM
98hotrodfatboy
No I'm not in Texas... New York... I am Familiar with Steve and GMR but I don't want to be stuck with a tuner that I have to rely on their input.. I want to be able to do what I want... If that Makes sense.. Don't want to be tied to anyone or is that how it is nowadays?
Old Nov 28, 2020 | 01:45 PM
misfitJason's Avatar
misfitJason
Tts or dynojet powervision with target tune. These are the two best.
Old Nov 28, 2020 | 01:55 PM
98hotrodfatboy
Why are they the best?...
Old Nov 28, 2020 | 04:56 PM
470004's Avatar
470004
I use the DynoJet Power Vision from Fuel Moto.
Old Nov 28, 2020 | 05:09 PM
98hotrodfatboy
I've watched a video on it and it seems that there are more steps to take to fine tume a download over the TTS.. Is that accurate..? Or are the pretty much same?
Old Nov 28, 2020 | 05:19 PM
TracerBullet's Avatar
TracerBullet
Another power vision from FuelMoto user here
Old Nov 28, 2020 | 06:03 PM
misfitJason
I have both and have used many others.
Powervision...live time gauges and when coupled with target tune, live time afr monitoring. Auto tune process is easy to use and the windows based tuning program is easy to use. Great support
Tts....most tuner friendly program. Everything is modifiable. Great for oddball motor and cam combinations for building maps.
Old Nov 28, 2020 | 06:08 PM
smitty901's Avatar
smitty901
Power vision from Fuel Moto. Buy it tell them what you have they will give yo a map that will down load in seconds and the bike will run great. If you chose run some auto tune runs off a copy and see if it get better for you. Fuel moto's canned map will like serve you just fine.
Save you a lot of BS with tuners and allow you the flexibility to make changes as you see fit.
Two weeks ago dropped 465C cam in. Jack pot mufflers and new AC. Fuel moto sent me a map. I already had their Power vision all I had to do was give them my order number. flashed the map and the bike ran prefect.
