Help! Vibration!
Old Dec 16, 2020 | 08:35 AM
Garage Queen Rescue's Avatar
Garage Queen Rescue
Originally Posted by Brayfield
they told me their wasn’t an alignment process
Dude I would find a new shop, somebody call me out if I'm wrong here but both mounts and the stabilizer under the tank need to be aligned properly otherwise the Dyna feels like an old rigid mount Sportster.
Old Dec 16, 2020 | 08:41 AM
Brayfield's Avatar
Brayfield
6th Gear
john jessup is opening up a shop near me so I’ll be the first customer lol
Old Dec 31, 2020 | 05:48 PM
Aaronstottle's Avatar
Aaronstottle
Do a search for shimming the motor mount, if the rubber ain't too bad. Made a huge difference on my WG. And yes, there most certainly is an alignment procedure. If a shop is telling you there ain't one, they're a buncha pud muskets.
Old Jan 4, 2021 | 02:35 AM
rogersachs's Avatar
rogersachs
Had a similar problem. Replaced mounts front and rear with no real help. Then I just had the tires re balanced and it did the trick. Quite smooth now with 40,000 miles.
Old Jan 7, 2021 | 10:32 PM
Clayjenson's Avatar
Clayjenson
I had a vibration almost front tire bouncing feel at freeway speeds
I had new blanced tires, spokes good...
shimmed a new oem stock front mount.
problem gone. Wrong way to deal with an imaginary problem but it worked for me
Old Jan 8, 2021 | 02:24 AM
bicio's Avatar
bicio
Check this one https://www.hdforums.com/forum/dyna-...vibration.html
the good thing about this forum is that most of the time your troubles were already discussed and possibly solved in the past......
Old Jan 8, 2021 | 05:04 AM
Brayfield's Avatar
Brayfield
6th Gear
i got a doctors appointment to check out my hands I’m thinking it’s carpel tunnel or some nerve issues
Old Jan 8, 2021 | 08:25 AM
Mchad's Avatar
Mchad
So you’re saying that’s been the issue all along?
Old Jan 8, 2021 | 10:51 AM
REW13's Avatar
REW13
how?? that will effect your hands going numb, not vibration feels... I have/had nerve issues in my neck arms just went numb.
Tozco
2018+ Softail Models
63
May 22, 2025 07:02 AM
Ric Kaysen
General Topics/Tech Tips
Sep 2, 2020 10:17 AM
Mikehoncho636
23
Nov 2, 2019 10:00 PM
ryder2u
Dec 10, 2012 06:44 PM
Dog Folks
May 29, 2005 12:42 AM
