There also some issues with the "new" primary automatic chain tensioner adjuster over tightening the chain and that was affecting the IPB bearing. If you wish to stay with the HD adjuster I think they are on version "C" or you could get an aftermarket adjuster.
The 2006 Dyna had serious issues with failures of the inner primary bearing.
The failures were not caused by defective bearings, the failures were caused by poor alignment between the inner primary cover and the transmission case.
To solve this issue both cases must be changed, or you could be routinely replacing inner primary bearings....
I do not see the Baker or any of those slip fit ball bearings as an upgrade.
It's what Dan said.
The inner primary and transmission cases lack locating dowels, thats why the IPBs go bad; its an alignment issue. The true fix is to replace the trans case and inner primary. This problem is unique to 2006 Dyna models.
