Adding fork oil? How?
Old Aug 1, 2007 | 01:26 AM
labfreak's Avatar
labfreak
Default Adding fork oil? How?
(Yes,I already searched, no info...) Can I add fork oil to '07 superglide forks without jacking it up ? Do I just unscrew the top cap and add?? Service Manual goes thru a whole thing of taking out springs etc. I just want to add about 1/2 ounce to each side to help with the "clunk" Any advise greatly appreciated!
Old Aug 1, 2007 | 05:45 AM
02FXDCustom's Avatar
02FXDCustom
Default RE: Adding fork oil? How?
ORIGINAL: labfreak
Unfortunately you have to take the fork right off. There is no filler cap. Follow the manual or buy a Chilton's or Clymer Manual. Both are invaluable purchases for about $25!
Old Aug 1, 2007 | 05:52 AM
dog06bob's Avatar
dog06bob
Definitely jack it up! Yeah, just unscrew the cap. May be easier to pull the spring out to add the oil.
Old Aug 1, 2007 | 06:50 AM
HOGRIDA_06's Avatar
HOGRIDA_06
Springs don't have to be removed, but you don't want to have any extra load on them. Jack it up. Even with out load the springs are under tension and if your not carefull the cap will shoot across the room and you'll have fork oil everywhere. If it were me I'd remove each leg from the trees and and work on them in a bench vise.
As far as adding oil to help with the clunk, don't count on it. It didn't help on my bike.
Old Aug 1, 2007 | 06:59 AM
rh8234's Avatar
rh8234
Rather than adding a little oil, try replacing the oil with a heavier oil. I put in the Screaming Eagle Performance fork oil in mine. It is a little heavier than the regular fork oil and reduced the clunking substantially.
Old Aug 1, 2007 | 12:27 PM
thrillseeker's Avatar
thrillseeker
Using one of these really helps
I got mine from http://www.rockymountainatvmc.com/pr...FamilyId=10975
Old Aug 1, 2007 | 01:50 PM
Bobber Rider's Avatar
Bobber Rider
i want to jump on the wagon with a different idea
there is a draining hole for the oil at the bottom of each leg
why not just remove the wheel and axle, pull the tubes out from the trees, turn them upside-down and fill oil from the bottom. thus eliminating the need of messing with the loaded springs and hard time rescrewing the caps on?
wouldn't it work that way?
Old Aug 1, 2007 | 02:19 PM
thrillseeker
ORIGINAL: Bobber Rider
the load in the spring isn't that much. If you are going to go through the work to take the entire fork off, you might as well just open the cap. There was another thread a couple days ago about something else and someone mentioned the drain holes are gone on the newer models... someone else said they were under the axle and to remove the front wheel (per what the dealer or a shop told them), and someone else said that was wrong... so I don't know if that is even an option on '06/'07.
thats also a pretty small hole to push fluid into.... a pretty small funnel, or a large syringe would probably be needed.
Old Aug 1, 2007 | 05:46 PM
mud's Avatar
mud
Picture below, #24 (what you are erroneously seeing as drain plug),
screws into #22, the seat pipe.
I may very well be wrong, but I do not think you want to remove
this screw until you are ready to disassemble the fork pipes.
And, it can be a real mortarforker to remove it.
I used a 1/2" impact and beat on it for about five minutes
before it broke loose.
When I put the WideGlide legs on my 06 SuperGlide I used the
heavier factory fork oil, and I like it better.
Also, hogrida is right about an oily mess, and springs shooting across the room.
So use precaution when removing the top cap.
mud
Old Aug 1, 2007 | 06:40 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
does anyelse see a pattern here? it appears the moco doesn't want the customer to do the little jobs anymore. derby cover screws that strip out on 1000 mile oil change outs and removing the whole bloomin fork just to change fork oil. "Scotty beam me up!"
