Tachometer
Old Feb 26, 2021 | 09:10 PM
diverherb's Avatar
diverherb
Default Tachometer
I have a 2005 FXD carbureted that I want to install a Drag Specialties tach on. I know the wiring from the tack and what the wires are supposed to wire into. My question is where can I pick up the trigger wire for the coil and what color is it. The ground, power and light are no problems I just dont know what color the coil trigger wire is and is there a factory wiring plug by the frame neck or will I have to go directly to the coil. Thanks.
Old Feb 27, 2021 | 02:31 AM
Giver of Doom's Avatar
Giver of Doom
I have a service manual for my 2005 FXDWG that also has a wiring diagram for your FXD. There is no negative terminal at the coil, only a 12+ and front and rear plug wires. Both tach and speedo signal wire is the LG/V coming from the ECM, it's the second pin from the right on your speedometer plug. The wiring diagram shows a tachometer and plug, maybe yours has the plug capped off next to your speedometer, if not just tap into the LG/V on the speedometer. Hope this helps!
Old Feb 27, 2021 | 02:50 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Wiring diagram here - 99949-05_en - 2005 Wiring Diagrams | Harley-Davidson SIP (harley-davidson.com)
A quick search brings up all kinds of wiring diagrams for Drag Specialties. Didn't the tacho come with instructions?
Old Feb 27, 2021 | 03:05 AM
Jackie Paper's Avatar
Jackie Paper
On my 04, it was the harness plugged into the speedometer. Interesting enough, I got the tac used off ebay. Did not come with the pin.
The dealership told me the pin only came in a service kit. The service wanted an hour labor to install it!? Ha Ha. It's the same pin in a 9 pin connector from old computer printer cables.
All that go around. Harley saved 5 cents by not putting the pin in the cable harness.
Old Feb 27, 2021 | 09:45 PM
diverherb's Avatar
diverherb
The tach wiring was not the problem. I was looking for what wires at the main harness at the frame neck to use. I located all but the "trigger" wire to the tach. All is good though I ended up going to the plug at the coil and tapping the G/w wire there.
800screws
EVO
Sep 11, 2016 07:14 AM
Fats4life
Jun 1, 2015 07:43 PM
07_Dyna
Aug 22, 2014 06:41 AM
Marktikko
Aug 15, 2011 03:56 AM
pontiac69
Mar 16, 2011 09:15 PM
