Oil
Phillips makes an aviation oil specifically for radial engines in a 25W-60 weight. Don't know how suitable it would be, but the V-twin has some things in common with aircraft radials.
Aviation oil is a poor choice for a motorcycle, for one thing, it lacks the ZDDP anti wear additive.
My point was a v twin and a radial aircraft engine are not alike. But thanks for the nitpick.
Ok, I`ll agree, a V twin and a radial aircraft engine have something in common, they have fins on the cylinders, they have pistons, rings and valves, but in reality they are worlds apart, just pull the front gearcase off one and you will see.
And oil used in those engines is not suitable for use in a v twin (or any ground based engine), there are too many superior lube types out there to even consider aviation oil.
OP:
The service manual may say SAE 60 is ok to use on an M8, but it also has a note saying to choose the oil based on the lowest temperature it will be used at, so SAE 60 should only be used above 80F, not really a practical choice in most areas.
I don`t think anyone is wearing out engines because they use 20w50.
