I have a 97 FXDL The left side (front&rear) blinkers stopped working. I have checked the bulbs, they are good, I have replaced the switch and the turn signal module and still no blinkers. the right side work fine.?. Any suggestions on what could be the problem?
If you checked everything and changed the blinker module check the plug under the
tank for a bad connection a wire may have pulled out or broke.
After that make sure your blinker fluid is topped off.
I had a 2005 fxdi where the bulb in the rear blinker wasn't making full contact with blinker. I added a tiny bit of solder to the bulb so it made full contact with the blinker and I never had another problem.
