Dyna wouldn't start.
Old Jun 21, 2021 | 03:36 PM
Crittenden's Avatar
Crittenden
3rd Gear
Default Dyna wouldn't start.
Has anyone had this problem and know the solution. I have a 2012 Harley Super Glide. Yesterday I was riding and I stopped somewhere and when I went to start my bike the battery dropped to about 2 volts I checked the connections and they were good. I tried it again and it started. I load tested the battery and tested the voltage regulator all good. Anyone have any ideas?
Old Jun 21, 2021 | 04:03 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
I have no clue why you put this in the Forum Issues section. It certainly doesn't belong here. It's not a Forum Issue. Make sure you post your threads in the right sections!
Izzo
Admin
Old Jun 21, 2021 | 06:25 PM
John CC's Avatar
John CC
Originally Posted by Crittenden
I went to start my bike the battery dropped to about 2 volts ... I tried it again and it started.
How did you determine the battery dropped to "about 2 volts"? I doubt such a battery could subsequently start the bike, so I'm guessing that's not what really happened. Describe exactly what happened the first time you tried to start it.
Old Jun 21, 2021 | 07:17 PM
Crittenden's Avatar
Crittenden
3rd Gear
I have a voltmeter on my bike. I found the negative terminal wire terminals where loose the bolt was stripped I tapped it out and put a new bolt in. I wiggled the wire around and started it many times. I think I fixed it if not I'll let you know.
Old Jun 21, 2021 | 07:25 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Anytime I'm working in the area of my battery I'll clean all the connections and I use blue loctite on the threads of the bolt keeping the loctite away from the cable eyes and batt. posts.
Old Aug 6, 2021 | 02:11 PM
vennom53's Avatar
vennom53
5th Gear
I just had a bunch of starting issues with my bike, a starter solenoid seems to have fixed the issue for now. They were like $10 so going to have one on had in the bag just in case.
Catchufirst
Forum Issues
May 17, 2011 08:27 PM
