Dyna Cyl Swap?
Old Aug 6, 2007 | 06:46 PM
OLDED's Avatar
OLDED
Default Dyna Cyl Swap?
Will the cylinders, pistons,etc. from an 07 96" Dyna bolt onto an 06 88" w/o mods? Will the 06 heads fit the 07 barrels? I appreciate any comments as to the practicality of that swap too. Thanks, OLDED
Old Aug 6, 2007 | 07:29 PM
shadowshady's Avatar
shadowshady
Default RE: Dyna Cyl Swap?
The latest issue of American Iron lists what is different from the 88 and the 96. The increase in cubic inches is from the additional 3/8" of stroke. If I understand the artical correctly the jugs are the same for the 88 and 96. The pistons are not the same as the 96 locates the pin higher in the piston.
I dont know if this helps. I found the article very informative and interesting.
Old Aug 7, 2007 | 03:46 PM
cardboard's Avatar
cardboard
Bought jugs off a 06 88cu model and put them on my 07 96cu model. The only difference is the stroke. If you git that far why not do a 103 indy build. and change the cams and have yer heads PP.
jims95sg
Exhaust System Topics
Jul 7, 2008 06:01 AM
damadman
Mar 29, 2008 12:21 PM
MattyD
Aug 8, 2007 02:39 PM
fullthrottle1
Jun 3, 2007 03:51 PM
budwfo
Jan 20, 2007 02:35 PM
