07 wide glide fork length?
Old Aug 7, 2007 | 06:02 PM
js1268's Avatar
js1268
Default 07 wide glide fork length?
anyone know? ....as you can probably figure out what i'm after
i got an '07 bob, and am trying to figure out proper fork length to keep within spec on trail if i were to rake out the triple trees at 3 degrees with a 21 inch wheel
...just doing my research, guys
thanks
Old Aug 7, 2007 | 06:37 PM
mud's Avatar
mud
Default RE: 07 wide glide fork length?
js, figure 34" top of trees to center of axle.
Post back withyour results here.
You should be fine on trail.
mud
ORIGINAL: js1268
thanks
Old Aug 7, 2007 | 07:06 PM
js1268's Avatar
js1268
thanks, mud....
i figured 34 inches
so with 29 degrees at the neck and with triple trees at 3 degrees, with a 21 inch wheel- you COULD probably use standard wide glide forks at 34 inches giving the '06 and '07 bobs a trail of 3.8 ...probably very safe.... but safe spec is between 4 and 6
so to bring things up to spec, us bob owners -if we wanted to use a 3 degree rake- would have to have at least 35 inch front forks ( i don't if any custom shops make 35 inch or longer 49mm forks)
the only other logical and very good option would be to do what WS6Formula did, which was to simply put on a wide glide front end- the trips on them are at 2 degrees... and with the 34 inch length shocks, you'll get a bit of extra rake, a wider front end, a 21 inch wheel...and will be within spec with a safe trail at 4.4
this works!
Old Aug 7, 2007 | 07:23 PM
uweldit's Avatar
uweldit
Just a question, are you going to lower the rear end? Just asking cause it could affect R/T calculation, prob not much, but...
I'm studying up on this for a winter project too.
UW
Old Aug 7, 2007 | 07:58 PM
js1268's Avatar
js1268
hi uweldit,
i won't be lowering the rear end, initially... and as part of the calculation, it doesn't figure in as a factor affecting the rake and trail, per say....but i suppose if it is lowered- which might affect the angle from the center of the rear axle to the top of the forks- it would probably bring the trail closer to spec if you wanted to use 3 degree trees with the 34 inch forks
Old Aug 7, 2007 | 10:22 PM
kerberos's Avatar
kerberos
Just need to be long enough so the front wheel reaches the ground.
(j/k!) Sorry couldn't resist.
Old Aug 7, 2007 | 10:31 PM
mud's Avatar
mud
Which calculator are you using js??
I'm surprised this setup doesn't fall within acceptable parameters.
mud
ORIGINAL: js1268
thanks, mud....
i figured 34 inches
this works!
Old Aug 8, 2007 | 07:15 AM
js1268's Avatar
js1268
hey mud, i'm using the one on RB Racing:
http://www.rbracing-rsr.com/advchoppercalc.html
...if i've calculated anything incorrectly, let me know!
Old Aug 8, 2007 | 09:55 PM
cardboard's Avatar
cardboard
Know where yer coming from .
I had a street bob last year before I got the wide glide. The ground clearance .
Old Aug 10, 2007 | 06:03 AM
js1268's Avatar
js1268
for those interested.... these guys make different length forks- mid and wide glide, over and under- at 49mm:
http://www.customcycleengineering.co...e2b85ba2267413
....you can get them polished or chrome
