2006 super glide
Old Oct 13, 2021 | 05:23 PM
jd140400's Avatar
jd140400
Default 2006 super glide
my right rear turn signal , tail light is out on my 06 superglide , tried changing bulbs no luck, also the right front is working fine, is there a fuse for just the right rear ? can also email to
jcajb97@gmail.com
Old Oct 13, 2021 | 08:38 PM
nevil's Avatar
nevil
Have you checked the wiring under the rear fender?
Old Oct 13, 2021 | 09:01 PM
jd140400's Avatar
jd140400
not yet , looking for the easy ( like a fuse ) 1st , i believe the wiring is under the chrome trim between the trim and the fender ,
Old Oct 13, 2021 | 09:18 PM
nevil's Avatar
nevil
There is not a separate fuse for each turn signal and brake light. There is a fuse diagram inside the fuse box cover, as well as in the owner's manual. Unless the bike was rewired at some point, which is possible, the wiring should be the same as mine, which is under the fender. It can be vulnerable there, especially if the bike's been lowered.
Old Oct 14, 2021 | 08:22 AM
SC_Compact's Avatar
SC_Compact
I had a 2005 FXDI where the rear turn signal stopped working. For some reason the bulb stopped making contact with the socket. I added a tiny drop of solder to the bulb, so it made better contact with the socket, and I never had another problem with it.
Willgirtman35
Mar 9, 2019 05:26 PM
ironrhino
Electrical/Lighting/Alarm
Jan 30, 2017 07:49 AM
biceps1
Jul 14, 2013 12:59 PM
hk_rebel
Dyna Glide Pictures
Jul 4, 2008 05:57 PM
dtsaul
Nov 3, 2006 10:00 PM
