rinehart pipes wrapped
gday thanks for info and pic.
buildup meaning on the inside of the curve in the pipe builds up
more than the outside.
can look untidy in tight bends.
i thought maybe thinner wrap would be a solution to this.
phil
And yes, I do believe you are right that the one inch wide
material would produce a tidier look.
However, I don't know what that would look like overall.
But, I've never used the one inch material.
Attaching two pix below, both sides of a tight bend.
On the inside, you have to choke up, and narrow the spacing.
The key is TIGHT wrapping, liberal soaking beforehand,
pay attention, unwrap if necessary,
and cinch it down TIGHTLY.
Results shown below are certainly tidy enough for myself,
and the girls I go with.
I'm working on a series of pages on my website
to illustrate my technique,
and if I see there is any interest in this sort of info,
I will be posting a link.
mud
I have done 3 lots of pipes.getting better each time.
I use stainless bands from c.v.joint boots.They tighten flat and almost dissappear in the paint.
good job.Phil
That looks great Mud.
I have been looking into black 2 in 1 pipes,
but after seeing how yours turned out,
I might go that route.
I think wrapped pipes would look real good.
The 2into1 should give you more power as well.
mud
I cant wait too see the finished product
Now for the questions...are you wrapping them wet or dry
..........any suggestions on how to wrap
..............................................what kind of straps are you using
..........any suggestions that you have will be very helpful
..got mine and ready to wrap the pipes on my project........
LOLIFE............................
I always wrap wet.
Straps?? High quality. no taiwanese walmartcrap.
suggestions and techniques are outlined in more detail
on my website.
That Sporty project is lookin really nice.
Keep up the good work.
mud
I just happened on this post as my net was down foraround 2 1/2 weeks after I moved.
Pipes look great!! I like them better than the ShortShots. Everytime I see your "bags" I want to order some Ammo cans and commence-a-hackin' on em .... maybe over the Winter !!
PsTaN
