NEWBIE Question
Old Aug 14, 2007 | 11:17 AM
ld78642's Avatar
ld78642
6th Gear
Default NEWBIE Question
When reading advertisements or catalogs for parts -- and you encounter the term 'billet' -- what does billet mean? I spent over 20 years in the army and to me that means either a place to live or a spot on an organization chart. I have asked some 'long time' Harley dudes and still do not get a consistent answer.
So, what's it mean? And how should it be considered when looking for stuff for your bike?
Thanks,
ld78642
Leon
Old Aug 14, 2007 | 11:23 AM
rap87's Avatar
rap87
Default RE: NEWBIE Question
I believe its a term to denote the quality of the parts chromed...its my experience that having billet parts are better than non billet parts and I imagine you will notice a price difference for billet vs non billet. Not sure all the technical reasons why billet is better, but I thought a guy at Kuryakyn had explained it to me once as the metals were of better quality when they go to chrome it or some such.
sprtnallover's Avatar
sprtnallover
Billet is also used commonly to describe motorcycle (or other) parts machined from a bar of metal (or billet), differentiating parts manufactured this way from those cast in a mold.
Old Aug 14, 2007 | 11:31 AM
mrb302's Avatar
mrb302
sprtn' hit the nail on the head...
Instead of molding metal, MIM (Machine Injected), casting, etc.. the part starts out as one solid block of metal, usually aluminum.
The block of metal (called a billet) is then machined, cut, lathed, etc. into the part.
Cons:
These parts usually cost more because there is a lot of metal wasted as shavings, or hunks cut from the original billet.
Pros:
The part is one solid piece of metal so it is generally stronger than a cast or pieced together part.
If you compare a billet part to the same part made by casting, the finish is usually nicer and smoother, even after chroming.
Old Aug 14, 2007 | 11:47 AM
matkiwi's Avatar
matkiwi
i learned something today !
jcsurf
EVO
13
Nov 21, 2018 09:55 AM
PBPDave
Dec 21, 2011 11:08 PM
DrPlastic
Feb 18, 2010 10:49 AM
Tattooedlife
May 17, 2008 02:43 PM
rockabillygrl
Oct 10, 2007 10:57 AM
