CV carb question
Old Jun 12, 2022 | 11:38 PM
Dudepants's Avatar
Dudepants
Default CV carb question
Ok hopefully someone can help me here: If I turn the air/fuel mixture screw in all the way and it doesn’t make the bike stumble at idle/change idle, does that mean the idle jet is too big?
Old Jun 12, 2022 | 11:54 PM
shaggieshapiro's Avatar
shaggieshapiro
What size is your idle jet?
Old Jun 13, 2022 | 07:48 AM
TexasScooterTrash's Avatar
TexasScooterTrash
It's a 2000 and stuff does wear out. Check the idle mixture screw packing. If that O ring seal is bad you'll never get the mixture adjusted right.
Old Jun 13, 2022 | 07:56 AM
Dudepants's Avatar
Dudepants
thanks @TexasScooterTrash I'm betting you're correct. I'm not sure I ever took that mixture screw out. Guess I better take a look!
Old Jun 17, 2022 | 11:10 AM
Dudepants's Avatar
Dudepants
Looks like you were correct @TexasScooterTrash , found that my carb had the mixture screw, spring and o-ring, but is missing the flat washer. I got an ez adjust mixture screw on order from CV Performance along with new packing pieces.
Old Jun 17, 2022 | 01:02 PM
TexasScooterTrash
FANF*CKNTASTIC!!!!!!! Glad I was of some help.
Old Jun 17, 2022 | 07:15 PM
TexasScooterTrash
I looked yer statistics up . . . you are the same age as my Retirement Project Bike, gifted to me from my Wife.
Old Jun 18, 2022 | 08:12 AM
Dudepants's Avatar
Dudepants
ha! that’s awesome
Old Jun 25, 2022 | 10:28 AM
Dudepants's Avatar
Dudepants
ok, so I got the new mixture screw and small bits in there and still couldn’t get the bike to “stumble” at idle while turning the screw in from 2 turns out. Then I swapped the slow jet out that was a 46 to a 45 and it still won’t stumble. Seems like something is wrong?
Old Jun 25, 2022 | 03:32 PM
Baird's Avatar
Baird
Manifold air leak? Up until this point was running OK?
