CV carb question
Old Jun 26, 2022 | 08:12 AM
Dudepants's Avatar
Dudepants
I don’t believe there’s a manifold air leak but I’ll recheck. Am I understanding correctly that turning in the mixture screw leans the mixture while turning it out richens it? If I can’t get it to stumble turning it all the way in, isn’t the idle jet too big?
Old Jun 26, 2022 | 10:01 AM
TexasScooterTrash's Avatar
TexasScooterTrash
Yep, lean is in. How's yer MPG? Low? Might wanna check out the enrichener valve, it might be sticking. I had a similar problem with my old 96 Wideglide. After tearing apart the CV-40 and rebuilding it that's what I found. So never used the "choke" after that. Set mix at 2 1/2 turns out. Test Ride. Decel popping, turn out (richer) 1/4 turn at a time till it's back to "normal."
Old Jun 26, 2022 | 10:44 AM
Dudepants's Avatar
Dudepants
MPG was around 33mpg with the 46 slow jet. Hmm. Maybe it’s time to pull the carb off and do a rebuild
Old Jun 26, 2022 | 06:59 PM
TexasScooterTrash
A side note on the CV-40. I converted EFI to CV-40 on my 07 Dyna 70,000 miles ago. Could never get great performance out of it after many tweekings. When I hit 100,000 I treated it to a 105" kit (after checking crank run-out.) Now it should have been great but it really wasn't. Did some research and found it's got limits based on CID. Swapped CV-40 for a Mikuni HSR 42. After dialing it in, I now have an Inter Continental Ballistic Dyna Missile. Still get 42/46 mpg . . . IF I stay with a light throttle.
ARNAV
Carburetor Related
Apr 12, 2021 06:24 PM
89FLHTC
EVO
Nov 13, 2015 06:15 PM
reservoir dog
EVO
Nov 9, 2013 01:38 PM
nwpwr22
Ironhead
May 30, 2012 03:15 PM
chillman9
Feb 17, 2008 07:34 PM
