Occassional problem
Old Jun 20, 2022 | 03:31 PM
de ed's Avatar
de ed
Default Occassional problem
2005 dyna with fuel inj. Every now and then the bike refuses to start. It runs great for days or weeks and then suddenly - no start. Let it sit for a few minutes or hours or days or weeks and bingo starts right up. It turns over fine, I've checked battery, coil, volt reg., switches, fuses, relays, wires, even the air in the tire and I can't find the problem ANY IDEAS PLEASE?
Old Jun 20, 2022 | 04:49 PM
Crazy's Avatar
Crazy
Have you checked for codes?
My '07 was doing that intermittently. Turned out to be the system relay was going bad, causing the fuel pump to go off and then on. It's a pretty cheap part.
Old Jun 20, 2022 | 05:58 PM
de ed's Avatar
de ed
Which one is SYSTEM RELAY and where is it located?
Old Jun 20, 2022 | 06:22 PM
MURPHCC1's Avatar
MURPHCC1
Hole in the high pressure fuel line INSIDE the tank, replace the fuel filter, hoses, and regulator in there.
Just a guess..........
OH......did you change your winter air to summer air in your tires?
Old Jun 21, 2022 | 05:49 PM
Crazy's Avatar
Crazy
Sorry my dyna is an '07 and HD made some big changes to the dyna line between '05 and '07. Don't know where it is on your bike. Do you have a service manual?
Edit: This is what the fuse box looks like in my '07, and #2 is the system relay.
Old Jun 21, 2022 | 05:56 PM
brakeless's Avatar
brakeless
More information would help. Does it crank? Do you hear the fuel pump run when you turn it on?
Old Jun 21, 2022 | 06:12 PM
de ed's Avatar
de ed
Same on my bike, #2. Already ordered a new one. The casing of the old one has some melted plastic. Thanks for the input. God bless.
Old Jun 27, 2022 | 06:42 AM
brownie4412's Avatar
brownie4412
Yep. My 04 did this. If you take the relay into a GOOD parts store they'll be able to cross reference it and save you a little coin.
Old Jun 27, 2022 | 09:19 AM
de ed's Avatar
de ed
Yes, I checked the relay and the plastic has a melted spot on it. Obviously, relay has a problem. New one ordered and should be in today. Thanks.
jory434
Aug 1, 2023 04:12 PM
FLHXSTD
Jun 6, 2020 04:58 AM
BaggerJohn
Oct 28, 2014 08:05 PM
theroadking11
Exhaust System Topics
Mar 7, 2014 09:16 PM
charris
Jan 23, 2014 11:44 AM
