Thanks sir. So I am getting 2"riser extensions and have the choice for these longer bolts, which should I get? 742288: 1/2x13x2 1/2" UNC for 1/2" extensions 742290: 1/2x13x3" UNC for 1" extensions 742292: 1/2x13x3 1/2" UNC for 1 1/2" extensions
Sorry for all the questions, but as a European guy these Inch size's are doing me in!
Show a pic of these "extensions" please
If they are just spacers installed at the bottom of the risers and are 2" thick , I would assume you need an additional 2" of bolt length ?
2 3/4 + 2 = 3 3/4
OK , they are just spacers.
adding 2" to bolt with 2" spacers will keep the same amount of thread engagement as stock ( 3 3/4 bolt)
I`m sure their 3 1/2 bolt will work fine also
OK, if they say that bolt is for 1-1/2" spacers, and you're getting 2" spacers, you might want to confirm it first before you order. Remove one of the bolts you have now and measure from the underside of the head to the end of the shank. Add 2" to that to get the new length.
