Rough shifting
Old Jul 21, 2022 | 02:31 AM
Joncasey60's Avatar
Joncasey60
2nd Gear
Default Rough shifting
My 04 Dyna low rider is shifting rough, every gear change I hear a big clunk. I know they are loud when shifting but it seems like it has gotten worse.
only 14,000 miles on it, changed all 3 holes with ams oil, primary and tranny fluid.
Any ideas what it could be?
Old Jul 21, 2022 | 03:47 AM
eighteight's Avatar
eighteight
Inspect primary chain tension. and / or adjust clutch ?
Old Jul 21, 2022 | 12:21 PM
nevil's Avatar
nevil
First step is to adjust the clutch and cable by the procedure in the manual.
Old Jul 21, 2022 | 12:24 PM
brakeless's Avatar
brakeless
2nd step would be check primary chain tension.
Old Jul 22, 2022 | 07:46 PM
benscratchin's Avatar
benscratchin
14,000 miles is not much for a Dyna tranny. Are you the original Owner? The transmission does require maintenance but, it's nothing but a gearbox, if you change the oil/fluid as required it will work well for a long time. The first (break in) oil change is probably the most important, it needs to be done on time.
The First and Second trouble shooting steps have already been mentioned above.
I suggest you go on Amazon, Ebay, etc. and find an H-D service manual for your year model bike and follow the required maintenance procedures. It has trouble shooting guides in it as well, Good Luck.
myerted
Jul 10, 2020 11:23 AM
BigRagu
Aug 21, 2017 07:24 AM
guard503
Jul 19, 2014 11:28 AM
AdrianVall
Feb 9, 2009 08:44 PM
Chief101
Jun 10, 2007 11:50 PM
