Hey all! Hoping someone can point me in the right direction. Rear wheel bearings apparently seized into hub?? I have tried everything short of applying heat, but a little nervous of doing that. Inner bearing spacer is tight up against both bearings and I can't get the spacer to move enough to get a drift punch on the bearing to tap out. No gap to get puller on back lip of bearing to pull out, keeps slipping off??? Anyone deal with this? What did you end up doing??? Stumped! Laced wheels, scared to apply heat for I will warp something?? 2017 Street Bob
Heat can and will ruin aluminum parts if you get it too hot. 600 deg will start to alter the hardness / strength.
Are you using the tool designed to remove wheel bearings, with the correct size collet?
Yes, finally got them out. Applied just a little bit of heat with my butane torch. They were a bear! Put anti-seize on them this time. Thanks everyone!
