06 dyna charging system
While testing stator resistance test good and ground test good. When ac voltage test I am not getting a reading at any rpm. Would this suggest stator needs replaced?
Something wrong with your meter or the alternator rotor magnets are broken loose.
PS. Welcome Jesse.
Hope you enjoy your ride here.
Only as a suggestion, create a signature
line for your bike, year, model, and all the
code letters.
You can add that bike photo to the signature too..
And be sure to make your next new post over in the new member welcome area to say hello.
PS. Welcome Jesse.
code letters.
Thanks a ton. That’s what I figured but I keep second guessing myself. Have the one piece rotor/stator kit coming. Ofc it’s back ordered my luck. Stuck riding the sporty for ten days or so!
That all doesn't make sense. If the resistance readings are good and the magnets are spinning then it will generate AC current. If the magnets came loose they'd be making a terrible racket. I'd take the cover off and look in there....
I took and old heavy screwdriver and tried to knock one off. Didn't budge.
I decided to try the don't strike . One smack on the OD and they just jumped together. Since they are trapped, rpm would not affect them.
Now just ridding down the road should not dislodge them.
My thoughts are since they no longer have those breaks, no AC.
(I think)
Don't think you're going to hear anything.
and you would be correct. Tore down last night. Thanks all I second guess myself too much!
