49mm Forks on early Dyna.
Old Sep 10, 2023 | 07:04 AM
mattyhaig's Avatar
mattyhaig
6th Gear
Default 49mm Forks on early Dyna.
Just put 49mm tripple trees on my 2001 Dyna Lowrider. The steering stops on the bottom tree just nearly slide under the block on the frame. Anyone come across this before?
Old Sep 10, 2023 | 10:34 AM
TexasScooterTrash's Avatar
TexasScooterTrash
Well the 49mm forks went on the NEW 2006 Dyna FRAME. Not a good fork stop?? Take off the trees and weld a small stop extension on it.
Old Sep 10, 2023 | 05:00 PM
Bubba Zanetti's Avatar
Bubba Zanetti
How’s it look? Post some pics.
Old Sep 13, 2023 | 04:18 PM
multihdrdr's Avatar
multihdrdr
The steering stem bearing's outer race cup sits farther up into the 06-later (49mm) frame Neck ... so the 49mm trees "sit" lower when installing on an earlier frame.
Be careful of hitting your tank with 49mm tree/tube without modification
Mowchai
2018+ Softail Models
Sep 1, 2021 01:05 AM
Johnny_reb
Aug 24, 2021 06:12 PM
DonN
Dec 21, 2017 09:50 AM
anothermatthew
May 18, 2008 10:01 AM
HANDLER
Dec 18, 2007 10:46 PM
