Wide Glide +4 extensions
Old Nov 26, 2023 | 06:17 PM
bulldog1776's Avatar
bulldog1776
Default Wide Glide +4 extensions
Thinking about doing +4 extensions on a 2011 wide glide, if I do it I would probably go to a 23" front wheel with no fender as well.
Is a kit like this all you need to do it? Thanks guys.
https://tcbros.com/products/fork-tub...yna-wide-glide
Old Nov 26, 2023 | 08:21 PM
Harley_ish's Avatar
Harley_ish
It's +4 on the FXD not WG
Old Nov 26, 2023 | 08:31 PM
bulldog1776
You are right I see that now. I guess someone probably makes a +4 for the wide glide. any ideas?
Old Nov 26, 2023 | 09:09 PM
TwiZted Biker's Avatar
TwiZted Biker
Look up stock tube lengths on both models, may be interchangeable if the tube dia. is the same.
Old Nov 26, 2023 | 09:15 PM
bulldog1776
Thanks. I found these, that are +4 on wide glide or +6 on others. So these should be right.
https://deadbeatcustoms.com/harddriv...-2-harley-fxd/
Old Nov 26, 2023 | 10:33 PM
Harley_ish's Avatar
Harley_ish
Those should work.
Be aware that instead of 4" over they may be more like 4-1/2" to 4-5/8" over compared to your year of WG tubes.
Old Nov 27, 2023 | 02:26 PM
Reindeer's Avatar
Reindeer
Yep, those will be 4" over (give or take) from your stock setup. Custom Cycle Engineering is another source, that's where I got mine.
Old Nov 27, 2023 | 08:42 PM
bulldog1776
Thanks. Your bike looks great. Beside the fork tubes and a seal kit, is there any other parts needed to do it? I read something about putting some 4" spacers somewhere.
Old Nov 28, 2023 | 11:49 AM
Reindeer's Avatar
Reindeer
If I remember right the fork tubes came with the necessary spacers. I think they're just PVC pipe.
Old Mar 30, 2024 | 10:02 AM
bulldog1776
Bumping this thread up for a related question.
If I get the extended tubes for the wide glide. Should I get a lowering kit for the front at the same time? Or leave the stock springs?
Thanks guys
