S&S Cover keepers length
Old Dec 13, 2023 | 03:32 AM
quija's Avatar
quija
As promised, here is a pic of the parts I have in my parts bin:
The part numbers were checked from a '85-'90 Softail parts catalog & '97 parts catalog for the EVO part numbers. The part numbers for the Twin Cam parts are from an '03 & a '16 parts catalog.
Both EVOs and TCs use the same Cover Spring Cap #17945-36B and Spring #17947-36. They also use the same o-rings, top to bottom; #11157 (superseded part #11293), 11132 (superseded #11132A), 11145 (superseded #11145A).
I sure hope I was able to keep all the part numbers straight as I copied them from notes I made.
Here's the pic of the parts, with two rulers in between for reference....
From left to right:
EVO bottom P/R cover #17938-83, EVO Spring Cap Retainer #17950-66 /
S&S Pushrod covers/retainer clips that come with S&S Quickie Adjustable Pushrod set /
Twin Cam Upper P/R cover #17948-99, Bottom P/R cover #17939-99, and Spring Cap Retainer #17968-99.
I do not knowingly have an EVO upper pushrod cover #17935-79B. So it is not in the picture..
Thank you very much. So I need 2,5" long cover keepers...
Old Dec 14, 2023 | 02:04 PM
quija's Avatar
quija
Well, I am confused. I got the email from S&S technical support that correct length is 2.4".... and it seems that 2.5" are really hard to get, but 2.4" are widely available.
Old Dec 14, 2023 | 03:21 PM
Max Headflow's Avatar
Max Headflow
Looking at the pic, they could be 2.4
Old Dec 14, 2023 | 09:51 PM
hattitude's Avatar
hattitude
A reminder, my pics are for S&S pushrod covers I purchased for, and used on, a 2003 Twin Cam engine... They fit and didn't leak... I went back to solid pushrods and so I also went back to OEM Twin Cam Pushrod covers...
Here are the S&S retainer clip lengths as measured by my two, different digital calipers;
Old Dec 15, 2023 | 02:52 AM
user 7209823083's Avatar
user 7209823083
If you still have your stock tubes and keepers at hand you can use them to figure this out. The combined length of tube and keeper should stay the same, so you need keepers that are as much longer than stock as your S&S tubes are shorter than the stock tubes, if that makes any sense.
Old Dec 20, 2023 | 06:50 AM
quija's Avatar
quija
Thank you for the measurement with the digital caliper. I got a link to S&S catalog (from tech support) - https://view.publitas.com/ss-cycle/2...3/page/120-121
2,400" - All stock height TC 96/103 with stock HD pushrod tubes
2,500" - 96", 100", 117", 103", 106" HSU with S&S pushrod tubes
So even S&S support tells me 2,4" the correct length is 2,5".
shankman
EVO
Apr 3, 2016 03:56 PM
live4rut
Sep 20, 2010 07:52 PM
55bob
Exhaust System Topics
Aug 5, 2010 07:42 PM
scatpac1
Feb 1, 2008 06:35 PM
