Headlight change possible??
Old Aug 28, 2007 | 10:42 AM
Swamphunter's Avatar
Swamphunter
Default Headlight change possible??
I would like to change my headlight to a bullet style headlight on my 1996 Dyna Lowrider (FXDL). I seems like it would be possible, although I have my indicator lights (neutral ind., turn signals etc.) that is mounted in the visor that covers the headlamp. Is there a relocation kit for the indicator lights and can the headlamp be swapped for a bullet style? Can someone point me in the right direction with preferrable a kit that allows this?
Thanks
From the new guy.
Old Aug 28, 2007 | 11:54 AM
DGlide04's Avatar
DGlide04
Default RE: Headlight change possible??
The change to a billet or WG type HL should be pretty easy, just drill a proper mounting hole in the lower triple tree clamp. Relocating the idiot lights is a little more of a pain. You might want to look into getting a cast off speedo mount from a 1999-2004 Superglide which mounted the speedo on the handlebar clamp, but has a cutout below the gauge for the indicator lights. Modifying the mount by removing the speedo mount ring and doing a little work on the remaining bracket could give you what you want w/o a lot of cash outlay except for the H/L.
Just my suggestion.
Old Aug 28, 2007 | 07:33 PM
DieselFTW's Avatar
DieselFTW
Stage I
Thats what i told him he could even get one off from a sporster. we could cut it down and i could powdercoat it. but will he listen to his friggen brother?
Old Dec 16, 2007 | 10:50 PM
0ut1aw's Avatar
0ut1aw
Has anyone actually done this and is there any problem with drilling the triple tree? Would it cause any integrity problems with the tree?
Old Dec 16, 2007 | 11:22 PM
JakeInMa's Avatar
JakeInMa
There was a thread not too long ago (not sure where on the forum) that someone drilled their new headlight and put the idiot lights in it. It looked like it was professionally done.
Old Dec 16, 2007 | 11:41 PM
metal_mike's Avatar
metal_mike
ORIGINAL: jakeiniraq
yep a quick click of the search button yielded this:
https://www.hdforums.com/m_2423863/tm.htm
Old Dec 16, 2007 | 11:53 PM
JakeInMa's Avatar
JakeInMa
ORIGINAL: metal_mike
Thanks MM, I did a search and couldn't find it. I probably didn't use the correct search words.
Old Dec 16, 2007 | 11:59 PM
0ut1aw's Avatar
0ut1aw
Thanks for that link that answers he problem of the idiot lights. Still curious if drilling the trees will cause any problems?
Old Dec 17, 2007 | 09:50 AM
Azgunner's Avatar
Azgunner
I ran my '02 FXDL for a few years w/ a bottom mount HL. Now it's got A stock WG front end. Idrilled the lower tree. No problems, it's only a little 3/8 hole. There will be no structural integrity issues. Do it you'll like it. I got rid of all the idiot lights, (who needs them) except for the engine oil light which I drilled a hole in the dash & stuck it in there.
tomass74
Jun 5, 2014 06:49 PM
Jackal
Nov 5, 2011 09:44 AM
Ozbernie
Mar 6, 2011 02:36 PM
Halfbuck
Mar 23, 2009 08:06 PM
eventiller
Oct 12, 2005 08:11 PM
