What the hell does this thing do? HELP!!!
Old Aug 29, 2007 | 06:57 PM
devils haircut's Avatar
devils haircut
Default What the hell does this thing do? HELP!!!
I installed my chrome primary cover today on my 07 FXD. After the bike was put back together, I realised that the old cover had a big black bolt threaded into it about an inch or two behind the hole for the shift rod. I assume that I should have taken it off the old cover and put it into the chrome one before reassembling the bike. Any one know what the hell it is? Please help. I dont want to drive the bike until this is resolved, but I have it stashed in an A-10 gun vault on base and can't keep it there over the weekend. Thanks.
Old Aug 29, 2007 | 07:03 PM
bikerRN's Avatar
bikerRN
Default RE: What the hell does this thing do? HELP!!!
I don't know what it is, but I just switched out mine to chrome last week and didn't do anything with it. I assumed it had something to do with the mid-controls which were swapped out for forwards before I took delivery. I just took my stock primary off and put the chrome one on. No problems so far.
Chris
Old Aug 29, 2007 | 07:05 PM
DGlide04's Avatar
DGlide04
I can't vouch for your '07, but my '04 had an inspection cover which had the shifter in the center, held on by two bolts, one long, one shorter on each side of the hole where the shifter shaft came through. I dont' know if it is the same on the later models that came with the hydraulic primary chain tensioner or not. hope that helps.
Does your primary look like this or is the derby the only opening?
[IMG]local://upfiles/1981/CD60C569488A47DC942BD4D89165D94C.jpg[/IMG]
Old Aug 29, 2007 | 08:20 PM
devils haircut
No, it doesn't have an inspection cover, only the derby. But It has a big black bolt or shaft with a torx head on it. Bigger than a T-27 like on the derby cover screws. It threads into the inside of the primary cover facing outward. There is no seal or gasket on it. I think maybe it acts as an internal brace maybe...?...
Old Aug 29, 2007 | 09:04 PM
Trotter's Avatar
Trotter
I cant find anything on it... I put mine back in...Sorry no help here.. There was one on my 07 soft tail also...
Old Aug 29, 2007 | 09:27 PM
devils haircut
Do you think maybe it's there strictly for manufacturing purposes? For example, some guitars have an extra hole bored into the body to stabilize it while the routing machines do all of the wood work. It's normaly in a hidden spot that will get covered up. Seems like a stretch, but you never know.
Old Aug 29, 2007 | 09:31 PM
JayFromPa's Avatar
JayFromPa
The front fender has one for hanging it for painting. Ya never know......................
Old Aug 29, 2007 | 09:34 PM
Trotter's Avatar
Trotter
Jayson you've been out in the garage too much again
Old Aug 29, 2007 | 09:41 PM
devils haircut
At least he's got a garage! I have to sneak into the gun shop on base to work on my bike. My flight chief is gonna be pissed when he sees my bike in there tomorrow! Luck for me, he's got a softail deluxe.
Old Aug 30, 2007 | 12:36 AM
DYNAMITE 1's Avatar
DYNAMITE 1
I think thats the self destruct butten
