High pitched noise
Old May 26, 2024 | 06:23 AM
TC88100th's Avatar
TC88100th
Default High pitched noise
Hi all,
so, off the back of an earlier thread my primary was making a really high pitched noise, turned out the chain was way too tight so loosened and all gone!
However, would riding a Harley be fun if it didn’t throw you a new problem every couple of weeks? So now, it rides a bloody dream no complaints in how it handles etc. however, two small things are happening which I can’t pinpoint in my HD service manual (thank you for the recommendation btw got one for Ł40)
when I change gear, if I’m going for it, I’ll change a gear and when I let go off the clutch, it makes a clunk noise, doesn’t affect drivability at all.
secondly, when the bike is hot, there is a high pitched noise which I can hear both by the clutch basket, and by the compensator when it’s in neutral, can’t see if it’s there when it’s in gear for obvious reasons.
thanks all
Old May 26, 2024 | 09:12 AM
Trumpet's Avatar
Trumpet
Helps if you post year and model.
Read thru clutch adjustment, and trans shifter adjustment. It could be that, which is easy to do. Or it could be the pawl failing.
As to whine, could be the bearings, if the chain was too tight.
It's all in the book, and hdforum search.
Old May 26, 2024 | 12:45 PM
TC88100th's Avatar
TC88100th
is it not in my signature? Thank you for the rest of your advice. Can I ask what a pawl failing is
Old May 26, 2024 | 02:52 PM
Harley_ish's Avatar
Harley_ish
Some data is not shown while using the Mobile version, including "signatures".
People forget, don't want to, or don't know how to switch over to the "full site" to see possible missing data
Although a username of "TC88100th" posting in the "Dyna" section could give one a good idea
Old May 26, 2024 | 03:33 PM
TC88100th's Avatar
TC88100th
haha it does give a few hints doesn’t jt
Old May 27, 2024 | 10:10 PM
Max Headflow's Avatar
Max Headflow
The primary chain will whine when hot if adjusted too tight.
fwj
Milwaukee Eight (M8)
Aug 3, 2021 04:18 PM
JensWest
May 15, 2018 09:48 AM
Irsh
Mar 19, 2016 11:10 AM
Rev zombie
Sep 20, 2012 10:22 AM
HardyHarHarley
May 17, 2009 10:53 PM
