My winter plan
Old Aug 30, 2007 | 03:40 PM
Swamphunter's Avatar
Swamphunter
Default My winter plan
Here is the winter plan I have for my 1996 Dyna Lowrider. Please tell me what you think, either way...pros and cons.
Of course the narrow glide front end is going...only to be replaced with either an OEM Wide Glide front end with 41mm forks, or the conversion kit and my stock 39's. I am not sure which whay I am leaning yet,and any suggestionswould be appreciated.
I am then lowering the rear end (shocks), by 1" - 1-1/2", whatever I can safely get away with as my wife rides on the back still.
I am replacing the OEM kickstand with an Arlen Ness forward (frame) mounted kickstand, and adding a side mounted license plate bracket.
I am adding a bullet style headlight and replacing that ugly headlight cover with a replacement bracketavailable from Headwindsto relocate the idiot lights.
I am also adding a set of Paul Yaffe (X-pipes), and then having it tuned to these pipes if necessary.
So..sounds like every other Lowrider conversion to date probably huh??
So..performance wise taking rake and trail into consideration, will I be alright just switchingto the Wide glide front end (stock length), and lowering the shocks by less than 2"?
Thanks
Swampy
Old Aug 30, 2007 | 03:48 PM
glide05's Avatar
glide05
Default RE: My winter plan
swampy -
like it - sounds well thought out.
i think the stock wg tubes are a couple inches longer than the lowrider.
if you lower the rear of your lowrider, and lengthen the front at the same time, you are really going to slow the steering down quite a bit.
if you keep your stock tubes, and lower the back, the sterring will slow a little - but should be fine.
I would go with a full front change with beefier fork tubes
Old Aug 30, 2007 | 05:59 PM
grizzly's Avatar
grizzly
I agree. And if you lower the rear, you can always slide the tubes up in the tree a little bit...
Should look killer!
Old Aug 31, 2007 | 04:59 AM
sporty2003's Avatar
sporty2003
i think you got a great planned going the beefer forks cant go wrong there. lowering the back you might want to do the front first. then go from there you may not havta drop it that far. but it does sound great . best of luck.
Sancheese
Jan 11, 2013 10:49 AM
Bagger Jim
Feb 17, 2012 07:32 AM
Azgunner
Apr 28, 2009 04:53 PM
urdollar
Apr 1, 2008 03:04 PM
sprinter
Apr 13, 2005 01:21 AM
