10 wide glide Sharkey after 75
Old Aug 2, 2024 | 06:48 AM
PGriordan's Avatar
PGriordan
Stage II
Default 10 wide glide Sharkey after 75
Just got this bike and was wonder how people feel on it over 75. Felt pretty sketchy at speeds. Has new fork seals. Definetly needs a front tire but was really surprised with the handling. It felt like my shovel. Is this a common complaint?
Old Aug 2, 2024 | 09:03 AM
Paintslinger16's Avatar
Paintslinger16
Active Streak: 120 Days
Kinda hard to understand, but if you know you need a tire, replace it first, probably before the 75 mph run, then report back.
otherwise, welcome
Old Aug 2, 2024 | 10:31 AM
PGriordan's Avatar
PGriordan
Stage II
otherwise, welcome
It just feels shakey at high speeds. im going to get a tire done next week and ill get back to you.
Old Aug 2, 2024 | 10:41 AM
Paintslinger16
Make sure it’s balanced and bearings are good. 75 shouldn’t be a issue
Old Aug 2, 2024 | 11:28 AM
nevil's Avatar
nevil
While you're doing the front tire, inspect the front motor mount. It's old enough to be concerned about it.
Old Aug 2, 2024 | 04:34 PM
Rusty Springs's Avatar
Rusty Springs
Have you tried adjusting the rear shocks? More preload may raise the back end and make it more stable.
Old Aug 4, 2024 | 08:56 AM
sharkey's Avatar
sharkey
All of the above and fall-away. My 01 FXDXT would shake a bit at triple digit speeds, especially after letting off the throttle...I set fall away up just 1/16 extra turn over proper setting and it was cured. Be wary of steering dampers; they can mask a problem
frenchy333
May 27, 2015 10:04 AM
pheur
Nov 18, 2013 09:18 AM
JoeBobber
Feb 26, 2010 10:06 PM
gdt3
Jan 10, 2010 01:36 PM
FastPitchFan
Apr 22, 2008 09:27 PM
