'16 fxdwg
Old Aug 7, 2024 | 02:20 PM
PeQuEa768's Avatar
PeQuEa768
Stage IV
Default '16 fxdwg
So, lately I've been having some minor performance issues. Ever since I replaced my grips. Which I'm sure has nothing to do with anything but, when I dump the throttle, I have a slight hesitation. Also when cruising at low rpm it will be running kinda rough and all of a sudden it corrects itself, smooths out, sounds better,....untill I come to a red light or somthin. I have an intermittent low idle too. I have checked my intake seals for leaks, replaced plugs, adjusted throttle cables, changed all fluids, inspected air cleaner element, cleaned breather bolts, and generally looked over everything to the best of my knowledge. I am almost certain it's an air fuel issue Im just out of ideas on what to check. I do not think it is anything serious because sometimes it runs perfect.
Old Aug 7, 2024 | 06:05 PM
FLSTC-Dave's Avatar
FLSTC-Dave
I would go back and perform throttle and idle cable adjustment procedures again. Bars left and adjust butterfly then fully right for final.
Old Aug 7, 2024 | 07:47 PM
NDI Inspector's Avatar
NDI Inspector
Alos might not be a bad idea to lube your cables while you have things opened back up. I use Inox lubricant. It comes in a needle bottle and is super easy to use. I think it's about $12 on amazon.
Old Aug 7, 2024 | 08:22 PM
nevil's Avatar
nevil
Did you check fuel pressure? How many miles on the fuel filter?
Max Effort
Aug 17, 2022 05:17 PM
Kytann
Aug 3, 2022 10:14 PM
mran
Jan 18, 2022 01:10 AM
toryhardin92
Jun 17, 2020 08:20 PM
darrin.nelson1
2014-2024 Touring Models
21
Mar 29, 2019 06:53 AM
