Dyna issues
Sorry, but I will have to disagree with whoever said that the brakes killing the speedo and other lights is "nothing that hinders the overall function of the bike ". IMHO, that is a big problem that affects the safe operation of that bike..
Which fuse did you replace? Are you sure it's the only fuse that blew?
In any case, there appears to be a short somewhere in the brake light system that is causing issues.... Whether or not that is the only problem, you'll need to find out.
You are going to have to get a voltmeter, a wiring schematic for your bike, and spend the time necessary to locate the short that is blowing the fuses when the brake lights are activated. You'll need to be systematic, and persistent... but you will eventually find it..
Good luck with the diagnosis...
At least now you know why he was selling the bike, regardless of the BS story he told you..
here’s a option, would be a lot of work, but so would chasing the gremlin you already have.
you are going to need a factory service manual either way.
