Oil Pump
Old Oct 24, 2024 | 01:43 PM
ChiefKMO's Avatar
ChiefKMO
6th Gear
Default Oil Pump
I have a 1997 Super Glide. Just replaced the oil pump and I can't get it to prime. I have been told to pack the pump with vaseline and I am told repeatedly to make sure the oil lines are in the right place. The lines can only go one way, the vaseline didn't work. Any ideas?
Old Oct 24, 2024 | 06:10 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Might wanna remove the oil pressure sending unit. Oil should to dribble out after the trapped air escapes.
Old Oct 24, 2024 | 09:23 PM
Max Headflow's Avatar
Max Headflow
Put oil in the tank?
Old Oct 24, 2024 | 09:52 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Pack the pump with Vaseline, haven`t heard that since the `60s.
Take the screw out of the pump where the check ball is, lift out the screen and check ball, the oil can now run down from the tank into the pump.
You can also pour some oil into the pump.
Old Oct 25, 2024 | 07:47 AM
Bubba Zanetti's Avatar
Bubba Zanetti
What purpose does packing the pump with Vaseline serve? I've never heard of this.
Old Oct 25, 2024 | 08:29 AM
ChiefKMO's Avatar
ChiefKMO
6th Gear
The mech at the Harley shop said it helps create a stronger vacuum to draw the oil in. I had never heard of it either.
Old Oct 25, 2024 | 08:31 AM
ChiefKMO's Avatar
ChiefKMO
6th Gear
Super Glide doesn't have a raised tank, the oil sump is attached to the tranny.
Old Oct 25, 2024 | 08:32 AM
ChiefKMO's Avatar
ChiefKMO
6th Gear
Oil sump is full. It is not a raised tank it is a sump next to the tranny.
Old Oct 25, 2024 | 08:34 AM
ChiefKMO's Avatar
ChiefKMO
6th Gear
I considered that but since it is a PDP will that make any difference?
Old Oct 25, 2024 | 08:56 AM
Max Headflow
If the hose or any part of the feed passage to the pump from the oil tank has any air leaks, the pump may not be able to draw oil in from the tank...
noriderz
Oil Archive (no new posts)
Dec 7, 2022 06:18 PM
Dynamick
Harley Davidson Videos
Mar 23, 2020 06:01 PM
kelton3
Jul 15, 2008 06:30 PM
darkdyna06
May 7, 2008 12:07 AM
MikesDad
Aug 21, 2007 08:20 AM
