Basic Conventional Oil in Twin Cam
Engine fluids have come a long way since the 60's & 70's when I first started working on cars/motorcycles. The cars/motorcycle engines themselves have also come a long way.
Today, the engine fluids from all the major oil suppliers will work in the engines they are designed for (re: marketed for), and probably many other engines outside their target "application". I can't remember the last time I have read or heard of an engine failure from the actual brand of oil that was used.
There is also a lot of marketing and hype over todays oils, as suppliers fight for market share.
There are two things to watch out for:
Labelling-
Often, there will be products from an oil brand that have different labels, but are the same product. For example, I heard a rumor and then contacted Bel-Ray about two of their different oil products: "Gear Saver Transmission Oil, 80wt", and their "V-Twin Primary Chaincase Lubricant". At the time, the Primary Lubricant was being sold at $2 to $3 per quart more than the 80wt trans oil. They confirmed in an email that both products are the same oil. They have different labels to appeal to two different end users....
Oil weights-
More recently, there has been a push from vehicle manufacturers to get the entire fleets in compliance with EPA requirements. They get fleet points for MPG, carbon footprint, etc., etc. The oil specs often will be designed for maximum efficiency (MPG) and longer change intervals. These specs aren't any better for the engine, but are better for getting EPA compliance points for a fleet of vehicles..
You can never go wrong with following the manufacturers "specifications". You should certainly follow the recommended weights and API specs during warranty. People just need to know that often, a manufacturers "recommendations" (different from specifications) are most often made for marketing reasons, not for better engine performance or longevity.
It's no wonder there are many oil threads. The information, marketing overload can be daunting for those with little vehicle maintenance or modification experience.
Having said all that, with the quality of today's oils, use what makes you feel best and fits your budget. As some have mentioned, good maintenance habits/intervals are more important than the brand of oil used.
FWIW.... For an air cooled engine, and living/driving around the SouthWest USA with 100°+ days, I choose a good synthetic oil for my engines. The synthetics handle higher temps before breakdown. I have no doubt a good mineral (dino) oil used in a good maintenance schedule would do as well...
Oh, and since this is an oil thread;
https://bobistheoilguy.com/forums/
Nobody has had any luck running basic 20w50 conventional oil, their engines fail before they get out of the driveway.
