Tail light wire issues
Old Jun 14, 2025 | 10:37 PM
Blue92's Avatar
Blue92
5th Gear
Acc circuit breaker only reads 7.6 and the circuit breaker with the blue wire reads 42 . I'm going to replace them all while im in there and see what happens
Old Jun 15, 2025 | 06:44 AM
RANGER73's Avatar
RANGER73
Going by what you said, the orange wire is the hot from the breaker to the brake light switch,
The red wire should show "0" until you press either lever,
The bike is a 12 volt system and should not show 42 volts.
The green wire is the running light and should show 12 volts with the ignition on.
The black wires are your blinker wires brown tape and violet tape, right and left respectively.
The lights on a 93 are self grounding and have no ground wire, so they must be grounded to bench test.
Old Jun 15, 2025 | 03:54 PM
John CC's Avatar
John CC
Originally Posted by Blue92
Acc circuit breaker only reads 7.6 and the circuit breaker with the blue wire reads 42 . I'm going to replace them all... and see what happens
This makes no sense. The blue wire reads 42 what? Don't start changing parts without first demonstrating that they are bad. It just adds to the confusion.
Old Jun 17, 2025 | 05:39 PM
Blue92's Avatar
Blue92
5th Gear
I checked the orange and red wire at the front brake switch. Both wires say 11.5 volts without the switch engaged and when I engage the switch, they both read 0 volts.
Old Jun 17, 2025 | 06:24 PM
Blue92's Avatar
Blue92
5th Gear
The rear brake switch doesn't change voltage at all with switch engaged or disengaged. 10.5-10.7volts
Old Jun 18, 2025 | 05:21 AM
RANGER73's Avatar
RANGER73
Are you testing to ground or wire to wire?
Sounds like a dumb question but humor me.
Old Jun 18, 2025 | 08:20 AM
Blue92's Avatar
Blue92
5th Gear
Testing to ground, as I said not too electrical savvy. I see now I'm suppose to test wire to wire, I'll get back to you
Old Jun 18, 2025 | 08:39 AM
John CC's Avatar
John CC
Measure from the test point to ground. When the switch is off (open), one side should be 12 volts relative to ground and the other side zero and the light should be off. When the switch is on (closed) both sides should be 12 volts and the light should be on. If you get different results, try disconnecting the wires to one switch and then testing the other one.
Old Jun 18, 2025 | 01:07 PM
RANGER73's Avatar
RANGER73
1 switch wire to ground should be 12 volts on 1 side 0 volts on the other until activated
when activated 12 volts on both sides.
This would be the same on both switches.
YZR
General Topics/Tech Tips
May 27, 2024 11:19 AM
LABFOMC
Apr 19, 2021 08:24 AM
krakenmoto
Apr 6, 2017 03:21 PM
1999 Wide Glide
Jan 13, 2014 07:33 PM
okgabriel
Aug 24, 2011 11:04 AM
