Headlight relocation. Higher up
Old Sep 17, 2025 | 10:30 PM
Rodent66's Avatar
Rodent66
Default Headlight relocation. Higher up
I’m going to install some different bars on my 16 FXDB, lower w/ a little pull back. I think the bike would look a lot better if the headlight was moved up a bit ( kinda like on a springer, it sits up high). Anyway anyone done theirs. Getting ready to do a winter make over after I get all my stuff together ( bars,grips,new riser bushings, maybe some flames on the tank, foward controls moved back 1-1/4” already made the parts, new brake pedal, front tire, ) plus some maint stuff. Bike should look a lot different ( and operate better I hope). Thanks for any pics or replies
Old Sep 18, 2025 | 05:25 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Is your headlamp mounted on a block? Can you get someone to machine a new part #20?
Old Sep 18, 2025 | 06:59 AM
Bubba Zanetti's Avatar
Bubba Zanetti
This is what I was thinking too. Should be pretty easy to fab up a mounting block.
Old Sep 18, 2025 | 11:07 AM
Rodent66's Avatar
Rodent66
Thanks for the replies. Yes, a longer/ higher block would work, but I want go up higher. Wondering if this might turn into a tuning fork( vibration ?) anyway the wiring is not long enough so I’ll have to add wire. Anyone know if these wires are the twisted can bus type ? I can’t see where they go into the frame but won’t budge, or come out any further. Thanks for your responses.
Old Sep 18, 2025 | 11:15 AM
Andy from Sandy
Wiring to the headlamp is not CAN bus it is power. The wires are in a grommet sleeve that is sometimes stuck to the wires during assembly to make it water tight.
It can only be too short outside of the bucket I imagine that could easily be extended from under the petrol tank. There could be like my bike a cable tie around a bundle of wires by the steering neck.
Old Sep 18, 2025 | 09:04 PM
Rodent66's Avatar
Rodent66
Thanks Andy. When I pull the tank I’ll check out the wiring. It runs into the frame and I bet you’re right about it being tied to other wires in there under the tank. Since I’m going to replace my bars I’ll have everything apart anyway. Wish I didn’t have to disassemble the terminal plugs to pull wire through the bars. ( PITA), but such is life. I’m old ,but think I’ll enjoy giving my Street Bob a facelift.
Old Sep 18, 2025 | 09:31 PM
Max Headflow's Avatar
Max Headflow
Here you go..
Amazon Amazon
Old Sep 19, 2025 | 03:28 AM
Andy from Sandy
A crash helmet for people with thick heads that haven't realised they have crashed!
arkstreetbob
Feb 8, 2011 10:03 AM
superrooster2003
Mar 18, 2010 09:12 PM
huff_custom
Dec 31, 2009 12:32 AM
Double00Aught
Jan 14, 2009 07:18 PM
Ratbasturd
Feb 10, 2007 12:15 AM
