2016 FXDLS Front Shocks
Old Sep 21, 2025 | 04:57 PM
Detroit Iron's Avatar
Detroit Iron
Default 2016 FXDLS Front Shocks
I'm in the process of replacing the fork seals on my 2016 FXDLS and noticed the shocks mechanics on the inside of the fork tubes are different. Is this normal?
It might be hard to tell in the photos, but one side, the hex cap is removable the spacer, then the spring under it. This side is also under pressure. The other side there is a rod attached to the hex cap and the spring is mounted on that rod.
Thanks for any insight.
Old Sep 21, 2025 | 11:01 PM
Harley_ish's Avatar
Harley_ish
Normal for some Harleys including your FXDLS ... Cartridge on one side & traditional damper rod on the other.
Do you have a Service Manual? It's covered in there.
Old Sep 22, 2025 | 07:58 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Old Sep 22, 2025 | 11:23 AM
Detroit Iron
Thank you!
Joe Jansen
Apr 22, 2019 09:32 AM
666streetbob
Apr 27, 2016 04:48 PM
zimm
Jan 21, 2013 12:29 PM
JCleary
Jul 15, 2011 04:57 PM
jm1211
Feb 22, 2010 10:00 PM
