WOW! DFO & Big Sucker *UPDATE*
Old Sep 7, 2007 | 10:43 PM
traveler's Avatar
traveler
Default RE: WOW! DFO & Big Sucker
Well, it will still help, as you are able to tune your bike more for power/performance, rather than economy and emmissions, which what your bike has now. Most of us are messing with the tuning for the power. If the bike has enough power for you now, as-is, then just leave well enough alone. I like a more performance oriented motor, hence, modifying the EFI, etc.
~Joe
Old Sep 7, 2007 | 11:45 PM
shoptroll's Avatar
shoptroll
ORIGINAL: Elginator
I'm pretty much a newbie too. A DFO doesn't really do anything for you if you still have stock pipes, does it?
Actually it will. My instructions came with settings for a stock bike and for one withpipes& a/c. The factory has them running too lean to meet EPA standards so a little extra go-juice will make the bike run smoother and cooler.
Old Sep 8, 2007 | 01:55 AM
traveler's Avatar
traveler
I agree.
~Joe
Old Sep 8, 2007 | 08:52 AM
ameristo's Avatar
ameristo
I have been running the TFI unit for a little over a year. I have D&D tuned headers and a big sucker air cleaner along with the stage one download. It does make a difference especially during acceleration and above 4000 RPM's. Also fuel mileage went from 49mpg bone stock to 45mpg with stage one download to 39mpg with TFI. So I installed a switch so I could turn it on for performance and off for economy.
Old Sep 9, 2007 | 10:09 AM
dougm1950's Avatar
dougm1950
Shoptroll - do the setup instructions go as far as specific pipes and a/c or just generically? I assume these are just starting points to keep from having to start from scratch, right?
Also, where did you mount the unit? Under the seat or somewhere else?
Thanks,
Doug
Old Sep 9, 2007 | 10:23 AM
shoptroll's Avatar
shoptroll
It just lists settings for stock and stage 1. You have to fine tune it from there to whatever your personal preferences are. Imay start another post to see if I can get everybody that's using one to list the performance mods that they're using and what settings they ended up with.
Old Sep 9, 2007 | 01:19 PM
dougm1950's Avatar
dougm1950
Thanks - did you mount it under the seat in that little area ahead of the battery?
Old Sep 9, 2007 | 06:03 PM
shoptroll's Avatar
shoptroll
ORIGINAL: dougm1950
Yep. You can't really mount it because of all the electrical connectors under there so I wrapped the sides of the unit with 1" x 1/8" sticky foam glazing tape and put a strip on the back also. That way I don't have to worry about vibration and wear with it lying on top of the harnesses.
Old Sep 9, 2007 | 07:59 PM
Sec Super Glide's Avatar
Sec Super Glide
The same set up I am running after three sets of pipes and a lot of switching around this set up is best so far.JMO
Old Sep 10, 2007 | 06:11 AM
CobraSnake's Avatar
CobraSnake
I would like an increase in power also. does anyone have any dyno results. im running a stage 1 mass air and the older version screamin eagle slipons. best my bike would do was 70 hp. how much more HP do you guys think a dfo could make also been pondering on buying some Vance and Hines Bigshots staggered.
