mey bike starts and runs fine and is charging after it warms up the engine light and battery light come on and it starts discharging very quick. does anybody have any ideas. it's a 2009 fat Bob i
How does it start after the discharge?
Put a meter on the battery while it's running and see what it does.
At 2k rpm and above it should read 14+ volts.
Watch what it does while at idle, should not go down.
If it does, could be the voltage regulator is gone.
Also, have the battery load tested.
Do the checks above, but, it sounds like when the bike gets warm something starts drawing a ton of current. Could be the regulator/rectifier failing from heat, or something similar. You might try to see if the regulator is suddenly getting hot. Measure the voltage and see if it suddenly drops off.
I would suspect the voltage regulator, the heat from the engine is making it expand and not make contact.
You can follow the 2 stickies in electrical to test the stator and regulator.
