Arlen Ness Big Shot
Old Sep 9, 2007 | 02:13 AM
Lonestar Superglide's Avatar
Lonestar Superglide
Default Arlen Ness Big Shot
Anyone have the Arlen Ness Big Shot? I am looking at a few different tuning options for my 2008 FXD and have not heard too much about the Big Shot.
Old Sep 9, 2007 | 04:26 AM
traveler's Avatar
traveler
Default RE: Arlen Ness Big Shot
ALOT of us on here are using the Big Sucka from Arlen Ness including myself. I like mine, and yes, you will need a re-tune after install. Many different types of tuners you can go with, and it really depends on how much you plan to do to your motor, as to how much adjustability you need. Might as well do your pipes at the same time prior to tuning.
~Joe
Old Sep 9, 2007 | 09:30 AM
shoptroll's Avatar
shoptroll
The Ness Big Shot is made for them by Doberick Performance and it's basicly a gen 3 DFO. It plugs into your fuel injector's electrical lines and includes bypass connectors for the stock O2 sensors. I just installed a Rev Tech DFO (digital fuel optimizer) on my 07 Streetbob and it works great. The Big Shot is a fancier unit with more adjustability. All these units will do is enrichen your stock fuel curve. If you only plan on a high flow air cleaner & high flow exhaust, these units work great. If you plan on head work & cams then you probably want to go with a unit that lets you create your own maps.
Old Sep 9, 2007 | 10:54 AM
Lonestar Superglide
OK, thanks for the imput. I am only planning to change the air cleaner and pipes, so I will look a little more into the Revtec DFO!
dugan
Jun 15, 2015 09:19 PM
dugan
2014-2024 Touring Models
Jun 15, 2015 09:09 PM
dugan
Jun 15, 2015 06:24 PM
GolferinOK
Nov 15, 2011 06:12 PM
fritzdog2
Feb 28, 2008 08:57 AM
