temp gauge
Old Sep 9, 2007 | 10:40 AM
hksb's Avatar
hksb
Default temp gauge
anyway to add a temp gauge that replaces the oil cap?
Old Sep 9, 2007 | 10:45 AM
anubisss's Avatar
anubisss
Default RE: temp gauge
YEs. I think it is called an oil temp guage.
Old Sep 9, 2007 | 10:47 AM
hksb's Avatar
hksb
right, but the stealer doesn't have one for my 06 'Bob so if anyone has any suggestions, please let me know
Old Sep 9, 2007 | 11:28 PM
pauletich's Avatar
pauletich
You can check Eastern Performance or JandP cycles.
Old Sep 10, 2007 | 07:02 AM
Bassman's Avatar
Bassman
They do not make on for the newer Dynas
Old Sep 10, 2007 | 08:18 AM
gman's Avatar
gman
ORIGINAL: Bassman
Correct, HD doesn't make a replacement for the dipsitick with a temp guage built in. Only way I can see to get a oil temp guage on a Dyna would be to get one of the fairing oil guages used on EGs, and get a tachometer like can and mount, and mount on the handlebars.Maybe mounted with a tach next to it, it may not look too bad. On the other hand, if you're running ok, and the AFR isn't extremely lean and you're not noticing excessive heat, not sure I would worry about adding a temp guage (although if HD did ever make a dipstick guage, I would buy one. Have one on my UC and it is great.)
Old Sep 10, 2007 | 08:37 AM
Dynamite17's Avatar
Dynamite17
ORIGINAL: Bassman
You could install this.
Old Sep 10, 2007 | 09:26 AM
dyna2319's Avatar
dyna2319
Iknow that they make one for the 06 wide glide. It is electronic and costs around 100.00 and I think you need to push a button to read it. . I just cant see paying that much for a guage that I will have trouble seeing while riding.
Dyna 2319
Old Sep 10, 2007 | 11:35 AM
Sal C's Avatar
Sal C
I had a HD one (with the button on it) for my 98 Dyna. Sold my Dyna since. It worked real well. HD is making one for the newer bikes with the screw on caps but they suck I've read. I read one thread where the guy brought back 2 of them because they broke. So, I'll go without one.
GittinThere
Oil Archive (no new posts)
May 8, 2018 10:30 AM
blown alcohol
Oct 24, 2009 06:44 PM
bobros
Mar 22, 2009 09:46 PM
Dogmann
May 10, 2008 05:59 PM
pino56
Apr 21, 2007 10:08 AM
