Inline Box - What is this?
Old Jan 24, 2026 | 07:34 PM
aharleyrider's Avatar
aharleyrider
Default Inline Box - What is this?
Recently purchased a TC88 Dyna Wide Glide and been going over it. Found this interesting box today and I have no idea what it is. I was thinking security system or resistance/balancer for the LED lights the previous owner added, but there are no labels, no stamps, nothing that I can use to identify it.
Can anyone identify this?
Old Jan 25, 2026 | 08:49 AM
hattitude's Avatar
hattitude
It looks to me like the Badlands Run/Turn/Brake module. They usually plug into the wire harness between the connector from the main harness to the rear lights harness. I have never used/installed that particular model, so can't say for sure where it plugs into.
It will allow for your rear turn signals to function as running lights, turn signals, and brake lights, rather than just turn signals as from the factory. I believe it also has a built-in resistor to stop the hyper-flash when using LED lights on a pre-canbus bike.
If you are using your rear turn signals as run/turn/brake lights (with or without LED bulbs) leave it in, unless it's acting up. If you want your rear turn signals to be turn signals only, remove it and all should work as from the factory...
Old Jan 25, 2026 | 09:35 AM
John Harper's Avatar
John Harper
I see violet and brown wires, which normally go to the turn signals. Hattitude has it correct.
John
Old Jan 25, 2026 | 09:36 AM
aharleyrider
That's precisely what it is, thank you for the help.
Old Jan 25, 2026 | 09:39 AM
Uncle Larry's Avatar
Uncle Larry
John
@hattitude usually is ":>)
Old Jan 25, 2026 | 02:35 PM
hattitude's Avatar
hattitude
John
Ha....
Even a blind squirrel finds a nut once in a while.....
Old Jan 25, 2026 | 03:21 PM
John CC's Avatar
John CC
Has anyone ever seen a blind squirrel? I would think blindness would be a significant detriment to longevity...
Old Jan 28, 2026 | 09:03 AM
hattitude's Avatar
hattitude
They are actually rather easy to spot.
Their red tipped, white canes give them away...
GFastng
Dec 10, 2024 09:45 AM
BigMike17
Touring Parts
Feb 14, 2024 01:20 PM
dontdropit
Touring Parts
Sep 24, 2021 08:22 PM
Socalledchad
Touring Parts
Sep 22, 2020 10:26 PM
jasonbum
Motorcycles For Sale
Sep 13, 2017 08:08 AM
