%^&*&^#@ Muffler removal
Old Sep 15, 2007 | 09:52 AM
blueglide88's Avatar
blueglide88
Default %^&*&^#@ Muffler removal
I've got SEII's on my Dyna. I"m trying to get the damn things off. The front was no problem, the rear is not coming off! It's loose, it can be moved side to side and up and down. It can only be turned slightly. The clamp is loose. Any tricks to getting this thing off? I don't want to ruin the muffler, I'll probably be putting it back on in the future, I just want to try out these new Screaming Eagle mufflers to quiet it down a bit for long trips. HELP!
Old Sep 15, 2007 | 10:12 AM
shoptroll's Avatar
shoptroll
Default RE: %^&*&^#@ Muffler removal
Place a wood block against the mounting bracket on the underside and drive it back with a 3 lb. hammer.
Be careful!
Old Sep 15, 2007 | 10:23 AM
voyager1's Avatar
voyager1
what he said . when i did mine,i bet i had to beat on them for one hour !!! just keep beating with wood. it will come off . make sure you torque the new ones to specs. good luck ...................
Old Sep 15, 2007 | 12:55 PM
darkkevin's Avatar
darkkevin
you said beating wood, he he
[sm=escape.gif]
Old Sep 15, 2007 | 01:15 PM
NEONNIGHT34609's Avatar
NEONNIGHT34609
some of them are riveted on i have seen people only rivet one on and the mounting will hold them both .. check behind the clamp and see if you dont have a small rivet holding it on
Old Sep 15, 2007 | 01:16 PM
labfreak's Avatar
labfreak
Spray WD-40, let set, slide off.
Old Sep 15, 2007 | 03:36 PM
SFD_207's Avatar
SFD_207
Remove the rivet.... I had the same thing... only one was riveted.
Old Sep 15, 2007 | 03:43 PM
NEONNIGHT34609
HUMMM where did i hear that
ORIGINAL: SFD_207
Old Sep 15, 2007 | 08:48 PM
blueglide88
ORIGINAL: NEONNIGHT34609
Damn I wish I would have read your post earlier!
That's what was holding it on, sure as ****. I moved the clamp back and there was a rivet in the rear pipe.
Thanks guys for all the replies!
Old Sep 15, 2007 | 09:49 PM
shoptroll's Avatar
shoptroll
Glad none of the ones that I've done had a rivet. That woulda pi$$ed me off!
