Rear axle nut torque?
Old Sep 25, 2007 | 04:39 PM
skip3406's Avatar
skip3406
Default Rear axle nut torque?
What is the correct rear axle nut torque?
I have the ’07 Dyna service manual P/N 99481-07.
The manual tells me tighten the rear axle nut to 92-98 ft-lbs (124.7-132.9 Nm)
Then it tells me when installing the retaining ring you can tighten it a little more if needed but do not to exceed 65 ft-lbs (88.1 Nm)
So what is the correct rear axle nut torque?
Old Sep 25, 2007 | 06:14 PM
mud's Avatar
mud
Default RE: Rear axle nut torque?
ORIGINAL: skip3406
Skip, 06 manual says 60-65 ft lbs.
mud
Old Sep 25, 2007 | 09:31 PM
96 Wide Glide's Avatar
96 Wide Glide
My 96 Dyna is 60-65lbs also.
Old Sep 25, 2007 | 10:44 PM
skip3406's Avatar
skip3406
Thanks for the reply Mud & 96 Wide Glide.
I didn’t think the manual was right.
This is my 1st Dyna and I did the 5,000 mile service last night and I took a guess and went with 62 ft-lbs because my ’05 softail manual says 60-65 ft-lbs 65 being the max. But my ’06 Sporty manual says 72-78 ft-lbs.
Thanks again, Skip
cpsychoholic
Sep 8, 2010 07:17 PM
running back
Dec 29, 2009 03:42 PM
STARMAN10548
May 26, 2008 12:27 PM
robertj74
Apr 11, 2008 05:09 AM
robertj74
Apr 10, 2008 05:05 PM
