Powercommander "accelerator pump" feature?
Old Sep 26, 2007 | 05:47 PM
riversnipe's Avatar
riversnipe
6th Gear
Default Powercommander "accelerator pump" feature?
'04 Super Glide with V&H Big Radius and Screamin' Eagle A/C. Installed powercommander with proper map for my setup...runs GREAT!!
I just added the "accelerator pump" feature with default "street" settings and can really feel the acceleration improvement. I just wondered who else has "accelerator pump" feature installed and what settings you are using?
Old Sep 26, 2007 | 05:52 PM
hk_shooter's Avatar
hk_shooter
Default RE: Powercommander "accelerator pump" feature?
I just started experimenting with mine, but I don't recall seeing a 'accelerator pump' feature on mine. You have a III USB?
Old Sep 26, 2007 | 06:02 PM
riversnipe's Avatar
riversnipe
6th Gear
Downloaded"PCIII USB Accelerator Pump Enable"from http://www.powercommander.com/powerc...downloads.aspxand loaded it per instructions. I can now access and change its settings. Check it out!
Old Sep 26, 2007 | 07:18 PM
hk_shooter's Avatar
hk_shooter
Thanks for that link. I downloaded it, too dark to try it out tonight. I will tomorrow, though [sm=biker.gif].
Old Sep 26, 2007 | 07:55 PM
songsmith's Avatar
songsmith
I first ran the setup for an 07 Super Glide with SE AC and 1.75 Rush pipes, even though my pipes were 2 inch pipes. It didn't really run good. Didn't have the accelerator pump set up with that one.
Then I installed the SE AC and SE Slipons setup and added the accelerator pump with it. It runs like a bat out of hell now! I think I may need to back off a little on the sensitivity of the pump as the throttle may be a little too responsive and the fuel milage has dropped a good bit. But I will surely keep the pump. May also cut down on the rear cylinder trim a little and the front trim a little less.
Still playing though and the real answer may be to turn overall trim up about 10 percent or so and then also cut the sensitivity on the pump back about halfway. That is my gut feeling at the time.
This is fun. Gotta say this bike screams this way!!! Outran a 2006 or 07 Pontiac GTO off a light to 60 with this setting. I ALWAYS back off at 55 and fully off at 60. That is one fast car and the guy has tinkered with it as well since it was even louder than the bike. It was a great race, and when it ended and we got to the next light we smiled and nodded at one another and then just took off normally the next time.
Tom
Old Sep 26, 2007 | 09:23 PM
dlstanf2's Avatar
dlstanf2
Yep! Songsmith has tempted me to do the accel pump download. I was curious about this as mine is an 06 with fuel injection. I thought that mod was for the carburated crowd.
Old Sep 27, 2007 | 06:46 AM
Shrug's Avatar
Shrug
I run it with the stock recommendations. I notice an improvement and remarkably no loss in fuel range per tank.
Old Sep 27, 2007 | 11:16 AM
hk_shooter's Avatar
hk_shooter
ORIGINAL: dlstanf2
I say do it. I'm going for a check out ride this afternoon, but from my preliminary observations (runnig in the driveweay and around the block once) it seems to be running OK. I thought it was only for injected bikes. Although there is a accelerator pump on carbs, Q-Jet's, Holly's, etc.
Old Sep 28, 2007 | 01:31 PM
hk_shooter's Avatar
hk_shooter
Seems to be a bit better, with accelerator pump feature added. I tried splitting the difference in the values for a starting point, seemed a little off. Went to the standard street settings and it seems a bit better. Still got a bit of 'fine tuning' it appears. Probably ride around with the lap topAnd the decelleration popping(from the stealers tune-up) is all but gone.Of course seat of the pants is no dyno... Anybody got one of the new Power Commander Tach display/ tuner units?
DADAWG
Mar 8, 2008 09:35 PM
flash1034
Mar 1, 2008 08:08 PM
Slyde
Exhaust System Topics
Oct 28, 2006 01:41 AM
wingnut79
Sep 7, 2006 02:26 AM
