07 Oil Level QUestion
Old Oct 8, 2007 | 01:56 PM
Dynamite17's Avatar
Dynamite17
Default 07 Oil Level QUestion
I just changed my oil/filter after 3000 miles from HD original dino to Mobil-1 VTwin 20W-50.
Prior to changing it, I noticed the cold level was halfway down the dipstick and the hot level was at the top of the crosshatched part, just as the manual states.
I changed and added about 2.5 QT (as the manual states, I guess .5 qt doesnt drain out when you change it - yes, changed the filter also).
After changing, here are my readings:
The COLD level is with the bike cold, rear cylinder was 60F. After running for 5 minutes, rear cylinder was about 240F (using infrared meter).
How is this explained? Opposite of the dino oil before changing to the M1 synthetic? Can others try to see if they get similar results?
B
Old Oct 8, 2007 | 01:59 PM
anubisss's Avatar
anubisss
Default RE: 07 Oil Level QUestion
The oil has to circulate through the engine and oil filter and then back to the oil tank. It is due to the design of a Harley engine and should be considered normal. If you read the manual, at least in mine it says to run the bike for a few minutes and then check the level again. Somone else can explain in more detail...
Old Oct 8, 2007 | 02:12 PM
Dynamite17's Avatar
Dynamite17
ORIGINAL: anubisss
Of course, I understand. Here is the funny part, my cold level is higher than my hot level, the opposite of what it was with dino oil. I ran it long enough, and let it set long enough before checking.
Old Oct 8, 2007 | 02:48 PM
labfreak's Avatar
labfreak
Dynamite, the syn vs dino oil won't make any difference in level. Are you checking it on the Jiffy stand? Also, are you screwing it down all the way when checking? Just asking the obvious..but I did it wrong at first.[&:]
Old Oct 8, 2007 | 02:57 PM
Dynamite17's Avatar
Dynamite17
ORIGINAL: labfreak
Yup, on the Jiffy stand (hate that term!) and level in the garage. Oil cap screwed all the way down when checking etc...
Old Oct 8, 2007 | 07:18 PM
WildBill76's Avatar
WildBill76
WOW! never seen this before.
Old Oct 9, 2007 | 12:45 PM
labfreak's Avatar
labfreak
ORIGINAL: Dynamite17
ORIGINAL: labfreak
Leaning on Jif stand, right? This really is a weird problem..
ral819
Nov 21, 2017 10:13 AM
DBLXX
2014-2024 Touring Models
31
Jun 6, 2015 09:57 PM
Tedjay
May 26, 2014 07:03 PM
jimski
Nov 4, 2009 06:51 PM
vandykemc
Oil Archive (no new posts)
Mar 23, 2008 12:18 PM
