Reflector removal
Old Oct 11, 2007 | 12:31 PM
warhawg's Avatar
warhawg
Stage II
Default Reflector removal
How much trouble to remove the reflectors off the front forks and the rear fender ,
Old Oct 11, 2007 | 12:34 PM
mvinc01's Avatar
mvinc01
Default RE: Reflector removal
I did a search for ya. There's lots of info on this topic. We see it come up every coupl'a weeks.
https://www.hdforums.com/searchpro.a...p;timefilter=0
I did remove mine. Used a hairdryer, some patience, and a bit of goofoff with a rag. Try to avoid the urge to use anything to pry at them (like a screwdriver, keys, knife, razorblade, wife's toothbrush, etc.).
Pretty simple procedure.
MV
Old Oct 11, 2007 | 12:48 PM
pwer pla's Avatar
pwer pla
Dental Floss (use like a wire saw) WD40 (spray between reflector) and about 10 min of time. Use WD40 to remove residual tape. Clean and polish. All done and looks better
Old Oct 11, 2007 | 01:54 PM
2007fxdc's Avatar
2007fxdc
I used some dental floss to remove mine a couple of weeks ago - front and rear. Definitely don't pry them off or try to force them off because you could scratch something or break the reflectors. I didn't even bother heating them up first and they came off okay. Iused my fingers with some force to sort of roll up and pull off the excess "sticky" left behind. Then, for the residue, I used goo-gone to get it off.
I tried the WD-40 trick and let it sit on the front forks while I was removing the rear ones. But the front ones didn't seem to come off any easier. So, it can be done without any sort of solvent if you don't have any.
Old Oct 11, 2007 | 02:05 PM
Cornhusker's Avatar
Cornhusker
I heated them up with a hair dryer and pulled them off with my fingers. Left almost no residue at all on the fenders and none on the forks.
Old Oct 11, 2007 | 02:56 PM
sintax's Avatar
sintax
I just finally got around to taking the rears off. I loaded up the area around them with Goo Be Gone and let it sit for awhile. One pulled right off and the other I used some twine I had in the garage. I had to do some major scrubbing (also with Goo Be Gone) to get the double sided tape off though.
Old Oct 11, 2007 | 03:26 PM
lolife's Avatar
lolife
grab with fingernails and pull...............rub off excess with thumb...................LO............. ................. ...................... .................
Old Oct 11, 2007 | 03:34 PM
Travlinman314's Avatar
Travlinman314
I tried the fishing line method, kinda hurt the hands and kept breaking the line.
Got a little pissed, started pulling them off. Yeah, they came off in pieces, not too worried about it, wann't planning to put em back on.
WD-40 and some good ol' fashion rubbing for the rest.
Don't forget the frame stickers now...
Old Oct 12, 2007 | 06:44 AM
encorebilly's Avatar
encorebilly
You used wrong line, try 20lb testberkley fireline and you won't break it,use gloves so you won't cut fingers.
Old Oct 12, 2007 | 06:51 AM
Chipstah's Avatar
Chipstah
ORIGINAL: encorebilly
You used wrong line, try 20lb test berkley fireline and you won't break it,use gloves so you won't cut fingers.
Definitely use gloves if you go the fishing line route - leave bike out in the sun first, and finish up with Goo Gone to get rid of the residue - easy 10 minute job max. I also soaked mine with Goo Gone first and they slid right off w/the fishing line.
Chip
