High RPM's
Old Oct 15, 2007 | 12:26 AM
davenportm's Avatar
davenportm
Default High RPM's
Folks,
Question for you or if you noticed the same and did something about it. I live in SoCal and the highways don't really have speed limits...knock on wood...soI usually coast at 75-85 MPH. Note that at this speed, I'm still a bit slow from normal traffic flow--generally. So my question is this...
I have a '05 Super Glide Custom EFI so only 5 gears. When going above 70, RPM's sound a bit high. No Tach to tell you how high though, but I'm sure it's sucking a lot of gas. I still have plenty of throttle left so I'm wondering if it's normal or other. I tend to get about 25-30 mpg.
I do have a stage I with V&H BS staggered.
Anyone have any suggestions other thantrading in for '06 or higher...someday but not today
Old Oct 15, 2007 | 12:49 AM
hondo96inch's Avatar
hondo96inch
Default RE: High RPM's
Regear, slow down, or don't worry about it. Hd or after market should have rear sprockets with fewer teeth. This might mean a shorter belt depending on what sprocket you can find.
I think andrews has larger front sprockets.
Of course the whole primary and swingarm have to come off if new belt is needed.
I wouldn't mess with anything requiring belt replacement. Ride it and be happy you get to run it hard.
Old Oct 15, 2007 | 12:52 AM
Herr Monk's Avatar
Herr Monk
I am new to the whole belt thing, but the basic idea seems the same as a chain. You could effectively change you final drive ratio by changing out your rear sprocket for a smaller one. A taller tire would have the same effect. You would loose a little getup and go, but it would drop your RPMs at every speed. The other alternative would be cracking open the transmission andchanging out your fifth gear for a taller gear. I am not sure what the options are out there for this stuff, but in principle any one of these would work.
Old Oct 15, 2007 | 12:53 AM
marcss's Avatar
marcss
I live in L.A. and I know what you mean. When traffic is light or moderate, 70 is slow in the fast lane. I have an '06 Dyna WG and really like the sixth gear but I'm not into it until I reach 70 mph. I don't know what the gearing is but I wouldn't think it wouldn't make that much difference. Maybe check your plugs for rich conditions and maybe a dyno. I'm stock (so lean) and I'm getting around 45 on fwy at 70 to 75. Maybe what you are getting it about right with your set up and 5 gears. Gas savings would not be worth cost to switch out tranny I would think.
Old Oct 15, 2007 | 01:00 AM
hondo96inch
All the gearing dope here. http://www.andrews-products.com/moto...lt_Pulleys.htm
Gearing can make a small or large difference depending on the amount of ratio change.
Old Oct 15, 2007 | 08:47 AM
mentor70's Avatar
mentor70
Yes, LA freeways are either dead stopped or your in the middle of a F1 race!
I have a tach on my 05 SG, and I cruise at 70 to 75 mph usually.
thats 3100 to 3500 rpms on the tach, It sounds like your winding up alot, but its acually in its sweet spot!
I just sold my SE 6speed and am saving up for a Baker DD6!
Old Oct 15, 2007 | 10:34 AM
hk_shooter's Avatar
hk_shooter
Can I ask you why you want the DD6 ovwe the SE unit?
Ink83
Apr 4, 2016 07:43 AM
Bumpandrun
EVO
17
Feb 15, 2016 10:24 AM
6 gun
Jan 30, 2012 09:12 PM
Gray_Drifter
Mar 28, 2010 04:14 PM
storytime
Apr 30, 2009 06:11 PM
