download for 25 degree injectors
Old Oct 16, 2007 | 11:00 AM
marcss's Avatar
marcss
Default download for 25 degree injectors
Awhile back I got the 8 degree injectors swapped out for the 25 degree on my '06 wide glide. It included a download to the ECM.
Does anyone know anything about that download? Is it the same or similar to the stage 1?
The dealer wasn't very knowledgable or forthcoming about it.
thanks. [align=right][/align]
Old Oct 16, 2007 | 01:54 PM
tbone52's Avatar
tbone52
Default RE: download for 25 degree injectors
Don't know. Renegade Harley Davidson in Alexandria, La. changed the injectors from 8 to 25 degree and the service manager told the mechanic that a remap wasn't necessary as those were the injectors that it was supposed to have in it.
Old Oct 16, 2007 | 05:49 PM
MrHd1's Avatar
MrHd1
WTF? I thought the new injectors were supposed to perform better. Are you guys changing to the new or the old??
Old Oct 16, 2007 | 10:57 PM
marcss's Avatar
marcss
I think the 06 dyna's were supposed to have the 25 degree like all the 07's.
Old Oct 16, 2007 | 11:09 PM
ItsaHarley's Avatar
ItsaHarley
Some of the '06's came with the 25deg injectors. I forgot the date they started using them. I could be wrong, but I don't see why they'd need a remap.
Old Oct 17, 2007 | 05:44 AM
tbone52's Avatar
tbone52
The early build '06 Dyna's had the 8 degree injectors. The MOCO factory changed over to putting the 25 degree SE injectors in after complaints about cold engine stumbling at starts from stop. Some dealers retrofitted the early build Dyna's with no problem. Some dealers had to be "convinced" to do the retrofit and some dealers refused. Some Dyna owners report no problems with the 8 degree injectors. Some Dyna owners found a dealer to change them out.
My '06 Dyna would stall at stop lights or signs when you blipped the throttle to take off. I went to three different dealers to get one to change the injectors. They said the remap wasn't necessary. It runs fine now. No stalling, stumbling or surging at low speeds. I get the same gas mileage, about 37 average town riding,with the 25 degree as with the 8 degree.
Old Oct 18, 2007 | 07:51 AM
jkenosh's Avatar
jkenosh
i also just got mine changed and the bike runs much better, i highly recommend doing it harley has a service bulletion out for this change
Old Oct 18, 2007 | 08:01 AM
Sammi's Avatar
Sammi
The back side of the Service Bulletin gives the steps the technician should take. If the injectors are changed to the 25", the bulletin says to update the ECM calibration.
Sammi
Old Oct 18, 2007 | 09:44 AM
ehc0720's Avatar
ehc0720
I saw it posted here about how you could tell which set of injectors you had but I can't find it now, anybody remember?
Old Oct 18, 2007 | 01:23 PM
man4mopar's Avatar
man4mopar
The first 06's had 8 deg injectors that flow 3.5 or there abouts and then they switched after a few months to the 25 deg that flows 3.9 roughly. They did it due to some haveing cold start isuues etc. If no remap is done it will most likely richen the open loop cells. In the closed loop sections it would tune back to the 14.7:1 ratio.
And if anyone is interested the SE injector that flows 4. something fits in the OE intake and is about half the price. One would need a tuner such as a PCIII, SERT, TCFI IID,Tmax or the likes.
