Added Extra Lighting - Pics added
Old Oct 25, 2007 | 12:30 PM
yuma's Avatar
yuma
Default RE: Added Extra Lighting - Pics added
ORIGINAL: ken01976
I put the same thing on my superglide last weak. Ran the one black wire from each lamp into a hole at the bottom of the headlight housing I drilled and spliced them into the yellow wire, so they come on only on low beam and auto turn off on high beam.
Now that doesn't sound like it would take the tree hrs labor I was charged, but mine has a separate switch to turn them off completely if so desired. One problem that I see already is that I was pretty sure Chrome was NOT necessary on my Superglide, but after adding these nice shiny lights I find myself looking at more pieces to start putting on her.
Old Oct 25, 2007 | 12:37 PM
ken01976's Avatar
ken01976
Mine cost me a hundred bucks with bulbs. Got them from someone local here on the boards. I have never put nething new on my bike. I hunt the classifieds and ebay and dennis kirk 75-90% off outlet.
Old Oct 25, 2007 | 12:40 PM
wreakmongrel's Avatar
wreakmongrel
Lights look great. Makes me want to add them to mine.
Old Oct 25, 2007 | 08:52 PM
PsTaN's Avatar
PsTaN
They do look good .... I've toyed with changing the whole look of my bike with those lights and some beach bars.
PsTaN
Old Oct 26, 2007 | 07:26 AM
ken01976's Avatar
ken01976
took about 30 minutes to install. If I had run them on their own circuit to a new switch with a highbeam cutoff, it probably would have taken me three hours though if done right. I'd have to take the tank off, blah blah blah...
Old Oct 26, 2007 | 09:49 AM
dlstanf2's Avatar
dlstanf2
Yuma, where's the switch? Please post a pic. I've thought about additional lights but have not pulled the trigger yet. I believe I might do mine with a solid state relay and set them to run either on low beam or high beam or not at all. May end up with the switch on the console of my FXD. I have the PIAA 100/110 Watt bulb in now - blue light. I'm not sure I am happy with the clear lens.
Like the look.
Old Oct 26, 2007 | 10:10 AM
yuma's Avatar
yuma
[quote]ORIGINAL: dlstanf2
Will try to post a pic soon. The switch is a push button that is mounted on the handlebar next to the high/low beam switch, not really a reach out and push position tho. Will look back for info another member had given me for a switch from cylcegadgets.com that is what you are talking about.
Old Oct 30, 2007 | 11:04 AM
yuma's Avatar
yuma
Hey! Took the pictures of the switch on my Dad's bike this weekend and will try to have them uploaded tonight. )
Kim - Yuma's daughter
Old Oct 30, 2007 | 11:57 AM
DGlide04's Avatar
DGlide04
I wired up a set of the passing lamps on my Dyna 2 years ago and they do provide a lot of extra light at night and to pesky cagers who have a habit of not seeing a bike. It gives other drivers 3 points of light, not just the single headlamp. As far as wiring, a few extra minutes to wire up an Autoswitch will work the passing lamps off the stock Hi/Low beam switch and will allow you to run them on high beam also. Check out this link for some more info:
http://www.autoswitch.com/2006/model...5p_index.shtml
It's a little extra wiring, but not much and pretty simple to install.
Good luck.
D'
Old Oct 30, 2007 | 11:58 AM
twofish's Avatar
twofish
Looks like they would fit with my windshield.
There’re also 20% off at Chicago Harley, tempting.
