How do you remove the battery?
Old Oct 26, 2007 | 02:32 PM
psmith007's Avatar
psmith007
Default How do you remove the battery?
How do you get at, and remove the battery from the street bob.
Old Oct 26, 2007 | 03:47 PM
Bluetoys's Avatar
Bluetoys
Default RE: How do you remove the battery?
1. find the battery
2. figure out which of the two wires is the positive wire at the battery
3. disconnect positive wire
4. disconnect the negative wire.
5. disconnect battery retaining strap.
6. remove battery.
voilĂ*!
Old Oct 26, 2007 | 03:57 PM
Cornhusker's Avatar
Cornhusker
.5. First, remove black screw centered directly under battery cover and remove cover.
Then follow steps 1 thru 5 outlined above.
HTH
Old Oct 26, 2007 | 04:13 PM
Bluetoys's Avatar
Bluetoys
forgot that part, sorry.
BTW, this is the battery cover:
Old Oct 26, 2007 | 05:12 PM
TOMMAY's Avatar
TOMMAY
Then throw away the black screw. The only time you'll ever need to remove the battery cover is when you don't have a screwdriver. [:@]
Good Luck
Tom
Old Oct 26, 2007 | 07:24 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: TOMMAY
Good Luck
Tom
You didn't, did ya?
DougJ
Old Oct 26, 2007 | 08:38 PM
06dynablack's Avatar
06dynablack
think you have 4& 3 reversed
1. find the battery
6. remove battery.
voilĂ*!
[/quote]
Old Oct 26, 2007 | 08:46 PM
hermit's Avatar
hermit
3rd Gear
Yea, usually the negative is first to break, last to make.That way if you happen to short to any metal -no problem.
Old Oct 27, 2007 | 02:03 AM
stewart1962's Avatar
stewart1962
Let me know how you get on. when i done this the alarm kept on going off, cant seem to find the fuse to shut it up.
cheers stewart
AydensPapa
Apr 19, 2020 09:59 PM
coop creek
Oct 9, 2017 07:03 AM
Beastly Angel
Feb 7, 2013 03:46 PM
arod6
Dec 28, 2009 10:13 AM
06WGRider
Oct 17, 2009 08:29 PM
