Surging / Popping noise
When I use to have the stock CV carburetors on my Harleys....until I switched over to S&S Super E. Every bike I had that had the CV carburetor was coldblooded. I wouldn't even touch the throttle, but would pull the choke all the way out. Then, I would push the start button and usually the bike would start within two trys. The bike would then have a fast idle, usually around 1,500-1,700. I would usually leave the bike this way for a about a minute, then push the choke in to half-way. While the engine is warming up on its own....this would always give me a good time to make sure all my lights and horn are working properly. I would also give the bike a quick lookover for anything that appears to not look right. I usually take about a minute to check all this stuff. After I am satisfied that the equipment is working properly....I typically like to place my fingers to the valve covers. If I feel any heat from them at all.....I usually ride away at that time taking it easy on the fairly still cold engine. After a few miles down the road, I push the choke all the way in and ride. If the bike is still spittering and sputtering....I pull the choke back out to halfway. While riding, I continue playing with the choke untilI am satisfied the bike is running the way I like.
One of my bikes have EFI. I don't just start it and ride off either. I start it and let it idle for a few minutes....at least until I can feel heat from the valve covers. The EVO really should heat up before ridden away....as the cylinders/heads are expanding due to heat. It has been my experience that if the EVO is not properly heated up....the cylinder base gasketshave a tendencyto start leaking. The Twin Cams don't have the problem of leaky cylinder base gaskets.....however, I still belive they should be treated the same manner as the EVO.
bob
